Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,051 Points: -13,308
If I finsih the Bounty sooner rather than later I was looking at this - Sergal Thermopylae. Tea Clipper 1:124 Scale http://www.cornwallmodel...mantua_thermopylae.html
I may still sneek this in, Just fancied something different.
Rank: Pro Groups: Registered
Joined: 21/03/2010 Posts: 270 Points: 837 Location: Nr. Dartford,
Know what you mean very nice. Will she be as fast to build as sail? I thought I would go for the other clipper, Cutty Sark, 'cos I was working at Greenwich when she was being restored and burnt. Really missed her masts when cutting down through the park in the morning. Fortunately they were already removed to Chatham for storage prior to the fire. The sight of those masts used to set me up for the day.
I know what you mean, in the early 80's I worked in a small printers down there (Greenwich Graphics) and I used to go and sit by her during my lunch breaks, but unfortunatley the bench was in the beer garden..oh beggar, I had to try the beer you know!
I lived just across the river to Cutty Sark in my misspent youth, and I think that with building the plastic models around at that time...mid to late 60s early 70s I fell in love with sailing ships, I used to love crossing the river on the old steam ferries at Woolwich then cycling to see Cutty Sark, oh the sweet memories of youth. I built the Del Prado version of Cutty Sark in wood though it almost came to blows when it came to applying the copper plating to her hull and making a thorough mess of it...bandages and plasters became part of my tool kit plus a book Mastery of The French Language For Dummies I recommend the build if you are considering something to do in between your Victory build though. John.W Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
You know what? There's more romance on here than on match.com. What is it about sail that drab grey slab sides don't have? What is it that steam locomotives have, and fishy smelling diesel electrics don't? What is it that airplanes with propellers have that modern jets don't? With the exception of Concord of course. Even that takes me back to Greenwich when the last ones flew back into Heathrow. All work stopped and we stood out in the street spellbound. Even management joined us without one word of complaint. Goodness I think I'm getting all sentimental. (Wipes away a tear) Match.com eat your heart out, I'm cancelling my sub. There is more kindred spirit on here in the last few weeks than I found on there in over a year. Am I getting old?
Joined: 20/03/2010 Posts: 226 Points: 647 Location: Merseyside
Tried to find that site. Does not appear to exist. Dave H
Current builds :- Hachette 1/16 Tiger Tank H.M.S Victory, Santisima Trinidad (Section), 1/8 scale Aston Martin DB5, 1/8 scale McLaren, YNWA
Joined: 21/03/2010 Posts: 170 Points: 549 Location: Lincolnshire
doremi495 wrote:Tried to find that site. Does not appear to exist. Try www.marcle.co.uk
Joined: 23/03/2010 Posts: 202 Points: 528 Location: Bedfordshire
Rank: Newbie Groups: registriert, Registered Joined: 11/04/2010 Posts: 2 Points: 6 Location: Folkestone
Shipmates ahoy. I can thoroughly recomend MARCLE MODELS the British importer of many ranges of card kit. There are several manufacturers of varying quality with ships from Roman to the latest in a wide range of scales. If you are interested give him a ring on 01494 765910. Regarding Plastic kits, be prepared to substitute wooden masts and spars. The plastic ones to scale are hopelessly feeble, Alternativly a hull model could be quite impressive Brian B.
Another pic of my time filler!! The hull and the decks went together ok in the end without too much trouble!!
Tell me about those plastic masts! Makes the rigging a very delicate tensioning operation. And then there are the duster storms to cope with. At least the rigging stops the masts, spars, and sails from getting lost. Its untangling the blighters. I can understand why they were often cut loose when hanging overboard!
Don't even go there with the rigging and masts!!! Did a plastic kit of the Cutty Sark, so i know whats to come!!
Joined: 17/03/2010 Posts: 301 Points: 941 Location: fife
nice to see others also have trouble with masts and rigging, i have the timber kit of thermoplye at the hull stage and am dreading the thought of having to rig her, prior to this i completed hms president and the rigging took about a month, then the cat got a hold of her, just about repaired the damage, at present building the uss constitution and again she is at the planking stage, so.... why am i thinking of hms victory current builds
Rank: Semi-Pro Level 2 Groups: Registered
Joined: 28/03/2010 Posts: 95 Points: 287 Location: dorking
Hi there all Just a quick question i was wondering if anyone on here has built H M S Surprise and if so would they say if its somthing to do as an BETWEEN project??? many thanks LETS BUILD AND BUILD HMS VICTORY HMS SURPRISE Can you help me with the volturno
Jack,I'm just hoping the larger scale will make the rigging less tedious
re hms surprise as an "in betweener" i think that we will probably have enough with the victory, surprise is a large enough project on her own current builds
Joined: 26/03/2010 Posts: 600 Points: 1,959 Location: Solway West Cumbria
Joined: 25/01/2010 Posts: 459 Points: 1,367 Location: Bridlington
Hi I'm doing DeAgostini's HMS Surprise, this one although, I think i will put her to one side and concentrate on my Victory as I will have help from all you guys and gals, so I'm going to batten down the hatches, and get stuck in to The Victory. 1.48 Regards
Rob
Bridlington.
