Rank: Pro Groups: Registered
Joined: 23/12/2018 Posts: 318 Points: 949 Location: Illinois, USA
Thanks for all the kind words. I'm pleased with the results so far. I was afraid that my fingers were too big and dumb for all the tiny bits. Pack 2 should be here next week. Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Rank: Superelite Groups: Registered
That cockpit looks the biz Mark Keep up the good work Regards Gray
Pack 2 Pack 2 has arrived. This session I will build the right side of the crew compartment. Hope you enjoy watching as much as i am in the build. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 2 In This session I I built the right side of the crew compartment. This kit is a lot of fun Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Rank: Administration Groups: Registered, Forum Support Team, Administrators, Global Forum Support Team, Moderator, Official Builds Joined: 09/11/2012 Posts: 7,909 Points: 22,907 Location: East midlands
That`s looking very tidy. Don`t know if you have, but now is a good time to check how well the two sides of the crew compartment match up and come together before you add the detail. Keep up the good work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:That`s looking very tidy. Don`t know if you have, but now is a good time to check how well the two sides of the crew compartment match up and come together before you add the detail. Keep up the good work. Regards delboy271155 (Derek) Thanks for the tip derek. The fit between the 2 sides and the floor is spot on. Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 2 During this session I tackled the first of the Avionics and other compartment details. I also created the carpet and fitted and glued the floor. Thanks for stopping by Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Looking very nice Mark. Mark
Thanks Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Joined: 13/02/2011 Posts: 2,226 Points: 6,798 Location: UK
Hi Mark, Very keen on watching this build come together ,also neat tidy and clean no a spot of glue. Trev. Work in progress:
Started San Francisco 2
tf64 wrote:Hi Mark,
Trev. Thanks Trev. Glue is not my mess of choice. It's painting of PE parts as you will see when I post my next update. Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 2 During this session I finished the avionics and details in the left half of the crew compartment. I have found my weakness , that is painting of photo etched parts. It always looks messy. Next paint stage I am going to slow WAY down and give more dry time between coats of paint, especially between the primer and first color coat. At least the messy bits are not in full view in the completed model. Seats are next Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 2 This session I concentrated on the crew seats. I had my first major screw up. While bending the PE seat frames I didn't pay close enough attention the the direction of the flanges that attached the seats to the side supports. Top fix this I had to grind out openings on the othe side of the seat support to allow room to attach the seat backs. A special note, when gluing the seat back halves together, make sure to clean out the glue from the notches for head rest attachment. Other than that, this was a good session. Come back soon Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
It`s looking good and you will get lots more practice with the seats and etch later in the build to perfect your skills. Like you said, take your time and when painting the etch try a practice piece first like the scrap from the etch frame. Try a light sanding with 1000 grade wet and dry first and then thin coats of paint with good amount of drying time. Keep up the good work and if you need some help/advise just ask. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:It`s looking good and you will get lots more practice with the seats and etch later in the build to perfect your skills. Like you said, take your time and when painting the etch try a practice piece first like the scrap from the etch frame.
Thanks Derek Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 2 This session I finished the interior of the crew compartment and then glued the 2 halves together. No problems were encountered. Next I start skinning the exterior. See you next time. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Hi Mark, Regarding painting Photo Etched parts, I was wondering if you have tried air brushing as this will give the finish you are looking for. Trev. Work in progress:
Hi Mark, you are certainly cracking on with this build, looking excellent. Mark
tf64 wrote:Hi Mark,
Trev. I have Trev. Problem there is I have a cheap airbrush that likes to spit paint so it overcoats small parts. I really need to invest in a better one. Thanks for the input. Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Under the Bench:
