Hi Darron Thank you for the comments, have attached picture for you to look at Ian. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Very nice work Ian...Looking good mate...Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Good stuff Ian Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Rank: Pro Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Looks good Ian. From your pictures it looks like the stern may need to be sanded back a bit more - until the brown laser cut on the keel starts to disappear.
Thank you Ian! Stefan is right the stern looks as if you will need to reduce the transom down some more to match the false keel. Take care not to reduce the keel! as soon as the transom matches the angle of the keel and there isn't a slot anymore in the centre stop. Darron
Hi Guys thank you all for the comments, darron thanks for the stern photos realy clear explination of what needs to be done. Ian ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
hi guys. Have reworked transom as per Darrons excellent guide. it saved me a few hours sanding down later when doing transome planking, thanks very much Darron. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 17/03/2010 Posts: 301 Points: 941 Location: fife
looks good Ian, as you say it will give a good grounding for the stern planking current builds
Rank: Elite Groups: Unapproved
Hi Ian It may just be the angle of the pictures but it looks to me like a shade more need to comes off especially where the transom meets the planks. The false keel should be flush with the transom for it's whole length. Here's mine for what it's worth If it is then ignore this. John
From the pictures I have to echo what John said.
Thanks guys. A bit more sanding to do. will post another picture when done. your comments are allways welcome Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Ian, This is what mine ended up looking like:
Hi guys. Gallery sanded back to stem post. please feel free to comment ian . ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Great job Ian Spot on Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Well done mate...Looking good... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Just sand off that laser stain and it will be perfect.
John
Thank you all for the comments and assistance in getting the stern correct. John the last part was sanded off after i looked at the pictures Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Guys. Just a quick update on my build so far. I have completed up to issue 32 on hull planking to the first four layers of planking on the lower hull. ian smith attached the following image(s): Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Ian looking great keep up the good work Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Great stuff Ian! Your planking is looking really neat, you can give yourself a well deserved pat on the back.
