Rank: Advanced Member
Joined: 08/07/2018 Posts: 30 Points: 90 Location: Canada
I recall seeing some posts about this but I can't seem to search the forums so I'm reaching out to see if anyone knew if deagostini was replacing these for free or am I stuck buying a 3rd party strip? both of mine have dim and failed bulbs.
Also are they supposed to flicker?
Cheers,
Joined: 04/09/2019 Posts: 36 Points: 108 Location: Kent, Wa.
Call their customer support number and they'll send you replacements. That's what I did for my R2D2. Bad thing is, they come from the UK and it takes 10 days. I'm on day 7, so we'll see what happens?
Not sure what stage of the build you are at, but if you are testing them out and using the battery pack, you may want to check the batteries as they will effect the working of the lights if low on charge. Mark Regards Markwarren (Mark) Admin
As far as I know, these batteries are straight from the pack, so they should be fresh.
