Excellent start Malc… Looking forward to following this one..... Regards Alan
Rank: Super-Elite Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 4,221 Points: 12,808 Location: ipswich
It really does look like an amazing kit. I bet it will be another masterpiece.
Thanks for looking in and the kind comments.
I've started finishing some of the engine parts and dry fitting.RM1 attached the following image(s):
The rocker covers need drilling 0.7mm to take the cast bolts. There's a couple of PE brackets that get held with these pieces. ( I can feel the eye strain already ) Covers then got sprayed Semi-gloss black.RM1 attached the following image(s):
Great start, looks an incredible kit to work with. Mark
The remaining components of stage 1 are those for the Supercharger and pedal bracket. They've been cleaned in the tumbler, drilled and dry fitted.RM1 attached the following image(s):
Hi Malc Im the same as yourself life getting in the way of things we enjoy and I too missed your build. Your doing your usual top job on this one, I built the 1/20 version ages ago and that was a sweet build just like yours will be. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Lovely progress Malc, looking very impressive.... Regards Alan
That engine looks great. It reminds me of the big 1/8 Pocher version. This is going to be a real showpiece.
Rank: Master Groups: Registered
Joined: 25/11/2018 Posts: 1,256 Points: 3,791 Location: Southeast UK
Kev the Modeller wrote:Brilliant work as always Malc, I just know this is going to be another masterpiece of miniature automotive engineering from you. I will be following your build.
Well done so far!
Kev Hi Kev. thanks for looking in and following my efforts. This one is quite a challenge. Malc.
Some finishing work on the Engine. Still a lot of dry fitting at this stage. The supercharger is just balanced in place. I can't commit too much to the final assembly as there is a load of piping that still needs to be worked through after the engine is mounted in the chassis. Malc.RM1 attached the following image(s):
Hi Malc, Your engine looks amazing!!! Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
That engine is perfect.Just goes to show how amazing the mfh kits can be in the hands of someone with talent.
Very nice work Malc, Mark
Superb work there Malc. I'm looking forward to seeing this one on the starting grid.
Superbly done, looks amazing..... Regards Alan
Thanks for the all the comments.
I'm going through this kit and prepping as much as possible before committing to bonding sections together. So each of the numbered stages are being drilled and fitted.
Next up is the ladder frame chassis which comes in two sections. These have been cleaned and drilled. Malc.RM1 attached the following image(s):
There are 4 PE pieces that are formed and located in slots on the inside of the frame. These provide the engine mounts.RM1 attached the following image(s):
