Rank: Pro Groups: Registered
Joined: 23/09/2018 Posts: 154 Points: 471 Location: Cape Town
The anchors installations are in progress. I added blocks for the palm of the anchors. Roeland attached the following image(s):
Rank: Master Groups: Registered
Joined: 21/04/2011 Posts: 1,039 Points: 3,140 Location: Buckinghamshire
This looks fantastic. I am very jealous of your modelling skills Roeland. Chris
Planning to add some anchor buoys. Roeland attached the following image(s):
Roeland wrote:Planning to add some anchor buoys. too large - back to the drawing board
Roeland wrote:Roeland wrote:Planning to add some anchor buoys. too large - back to the drawing board Does anybody now the size of the buoys?
Hi Roeland, It's just awesome looking at you modelling skills. I have attached a few shots of HMS victory anchor buoys and although I don't have dimensions, I assume that with a bit of scaling and comparing to the size/spacing of the rigging and ratlines, a fair attempt could be made to create one? goddo attached the following image(s):
I made it smaller.... Roeland attached the following image(s):
2 Anchors are now in position. Roeland attached the following image(s):
Those anchors look good Roeland and the buoys seem well in scale. Brilliant. Chris
All 4 anchors are now in place. Roeland attached the following image(s):
A really superb build! Congrats!Greetings, Walter
Starting to make the forecastle guns. Roeland attached the following image(s):
Forecastle guns are now nailed to the deck - a tricky operation with all the rigging in place. Roeland attached the following image(s):
Another question - as per attached picture I noticed these proportions to be wrong on my model and several others on the forum. Some however managed to get this right? Did I do anything wrong or was it a matter of correct modification? Roeland attached the following image(s):
Rank: Elite Groups: Unapproved
Luck rather than judgement I suspect. There are so many sources around for this, you can take your pick.
Busy making the ship's boats. I hope to add 2 scratch build 25 ft cutters. I could not find any plans so I based it on the 18 ft cutter; just a bit larger and added an extra support (on the right; one frame finished ; one still to be cut). I'm not sure where to get such a thin plywood so I laminated 2 sheets of 0.8 mm balsa wood; then reinforced with book binders glue before cutting. Roeland attached the following image(s):
Joined: 11/11/2009 Posts: 3,432 Points: 10,280 Location: Bâe Colwyn, Wales
Doing a super job. She's looking very nice indeed. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Playing around with the pinnace. Roeland attached the following image(s):
