Beautiful work, your usual very high standards I see..... Looking fab..... Regards Alan
Is it correct that modelspace are no longer doing this build.
Rank: Master Groups: Registered
Joined: 21/04/2011 Posts: 1,027 Points: 3,107 Location: Buckinghamshire
Steve1701 wrote:Is it correct that modelspace are no longer doing this build. True or not, everything is out of stock at the moment anyway. Due to the pandemic, no doubt. I was just wondering if it's still possible to re-order individual stages if, like me, one messes up. Or parts are broken/missing?
Rank: Superelite Groups: Registered
If you have a subscription you should be ok asking for replacements. Although you might have to await stock
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Thanks for your kind words Trev and Alan. I have done se work on the fittings,I managed to break the steps while taking apart the original model so I had a go at making my own from walnut I also made the bits from the same material. nightwisher attached the following image(s): Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Lovely work with those bits.... walnut is a beautiful wood when worked correctly... Regards Alan
Thank you Alan. Have been working on the 10 guns pretty much as per the instructions except I added small pieces of 2x2 wood to fit under the carriages to make them look more like the real ones as I thought the wire axles looked a bit skinny. I also sanded the rigging blocks to make them a bit smaller File Attachment(s): nightwisher attached the following image(s): Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Oops messed up on the pics nightwisher attached the following image(s): Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Looking excellent, very nice work. Mark
Nice clean work on the cannons. I like the idea of a wood strip to hide the brass axles. Too late for me to do this on my model though. Chris
Rank: Semipro Level 1 Groups: Registered
Joined: 23/03/2010 Posts: 62 Points: 189 Location: bristol
Excellent work there very neat and tidy, outstanding workmanship.
Thanks for looking in and leaving comments. I have been working on the upper deck for the last few weeks,here's a last look at the finished guns before they get covered. File Attachment(s): nightwisher attached the following image(s): Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Coming together very nicely. Mark
Very nice and tidy work there night wisher. I wish my gun rope-work looked as good as yours. Well done sir. Chris
Beautifully done, love the little changes you've done to the guns.. Very well done indeed..... Regards Alan
Thank you do much for the kind words. I really did not like the kit version of the cabin walls so have been messing about with bits of walnut to to try and come up with something closer to the real thing. nightwisher attached the following image(s): Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Have to say I really like what you've done with the cabin walls, a really nice improvement..... Looks great.... Regards Alan
A very nice upgrade to the cabin walls. Chris
Rank: Administration Groups: Registered, Forum Support Team, Administrators, Global Forum Support Team, Moderator, Official Builds Joined: 09/11/2012 Posts: 7,910 Points: 22,910 Location: East midlands
Very nice personalised upgrades in your build. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi everyone, sorry I haven't posted for a while been busy at work and doing up my garden. Anyway I have managed to finish the scratch built cabins, I quite enjoyed doing this though very time consuming. The poop deck is finally finished and I have trimmed the gun deck opening. nightwisher attached the following image(s): Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
