Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,312 Points: 22,243 Location: Northamptonshire, England
Issue 1
I have just received my first pack. In issue one, you get the first black Rook which has a magnetic base you can move with the wand, which also come with this issue.
Here are some photos of the parts received. I have taken the pictures in my studio with a Harry Potter themed background.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 2
Here you receive your first white Pawn, which when tapped on the shield it will explode into two halves.
You also receive a full-size cardboard chessboard and pieces.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
