 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,855 Points: 17,717 Location: ipswich
STAGE 77:
Left side rear panel.
Pic 1: Fit the vent 77B into the side panel 77A as shown.
Pic 2: Fix from behind with 2 x AP screws.
Store safely for now.
STAGE 78:
Left side rear panel 2.
Pic 1: Locate the 5 x side clips. They are each numbered on the back RL1 – RL5.
Pic 2: Fix the trim 78G to the side panel 78A with 2 x AP screws from behind.
Pic 3: Fit the other 3 x strips 78H, 78I and 78J as shown. Fix 78H with 2 x AP screws and the other two parts with 3 x IP screws from behind.
Pic 4: Fit the clips RL2 – RL5 as shown.
Pic 5: Fix the parts with 4 x AP screws from behind.
Pic 6: Fix RL1 to the vent 78A with 1 x LP screw from behind.
Pic 7: Fix the assembly to the side panel with 2 x AP screws from behind.
Pic 8: Retrieve the main body and fit the side panel in place.
Pic 9: Fix from the inside with 4 x DM screws.
STAGE 79:
Right side rear panel.
Pic 1: Fit the vent 79B into the side panel 79A as shown.
STAGE 80:
Right side rear panel 2.
Pic 1: Locate the 5 x side clips. They are each numbered on the back RR1 – RR5.
Pic 2: Fix the trim 80G to the side panel 80A with 2 x AP screws from behind.
Pic 3: Fit the other 3 x strips 80H, 80I and 80J as shown. Fix 80H with 2 x AP screws and the other two parts with 3 x IP screws from behind.
Pic 4: Fit the clips RR2 – RR5 as shown.
Pic 6: Fix RR1 to the vent 80A with 1 x LP screw from behind.
Store safely for now.roymattblack attached the following image(s):
STAGE 81:
Engine surround.
Pic 1: Fit the element 81D into the grille 81 B as shown.
Pic 2: Fit the other grille 81C in place on the assembly, the other way round.
Pic 3: Fit the assembly to the engine surround 81A as indicated.
Pic 4: Fix the blocks 81E to the surround as shown with 2 x AP screws underneath.
