1989 Batmobile Official build STAGES 63 - 68 Options
#1 Posted : 04 November 2026 15:04:15
STAGE 63:
Fuel tank hoses.
Pic 1: As you did before with the other fuel lines, feed the 4 x washers 63-4 over the hose 63-1, keeping them equally spaced along the hose.
Then feed the 2 x smaller tubes 63-2 through the outer holes in each washer.
Pic 2: Fit the fuel filler neck 63-3 as shown, paying attention to where the hose and tubes connect.
Store safely for now.
#2 Posted : 05 November 2026 13:38:16
STAGE 64:
Steering frame.
Pic 1: Fix the column parts 64-2 and 64-3 together with 1 x A screw as shown.
Pic 2: Fit the column into the frame 64-1 and fix the cover 64-4 over it using 2 x D screws.
This page was generated in 0.208 seconds.
