 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,838 Points: 17,666 Location: ipswich
STAGE 39:
Coolant reservoir.
Pic 1: Retrieve the assembly from stage 38 and fix the bracket 39A in place as shown with 2 x G screws.
Pic 2: Fix the reservoir parts 39B and 39C together with 2 x B screws.
Pic 3: Fix the vent fitting 39D to the tank as shown with 1 x B screw.
Pic 4: Press-fit the cap 39E in place.
Pic 5: Fit the assembly to the bracket just fitted on the top of the frame as indicated. It will only fit one way.
Pic 6: Fix from underneath with 1 x B screw.
Pic 7: Retrieve the pipe 38J and fit it to the end of the vent tube 39D.
Pic 8: Store safely for now.
STAGE 40:
Power electronics.
Pic 1: Fix the bracket 40A to the cross bar 40B with 1 x G screw.
Pic 2: Fix the bracket 40C to the cross bar 40B with 2 x G screws.
Pic 3: Fix the cooling tube 40D to the electronics base 40E as shown with 1 x B screw from underneath. The parts will only fit one way.
Pic 4: Fix the base 40F to the assembly with 6 x B screws.
Pic 5: Fix the fitting 40to the assembly with 1 x B screw. It will only fit one way.
Pic 6: Fix the power unit to the cross bar as shown with 4 x B screws.
STAGE 41:
Air pumps and pipes.
Pic 1: Assemble the pumps and bracket parts 41A, 41B and 41C as shown.
Pic 2: Fix from behind with 2 x B screws.
Pic 3: Retrieve the assembly from the previous stage and fix the pump bracket in place where indicated using 2 x G screws.
Pic 4: View from the other side.
Pic 5: Fit the pipe 41D in place as shown.
Pic 6: Fit the pipe 41E where shown.
Pic 7: Retrieve the left frame assembly and fit the vacuum tank 41F where shown, fixing it with 1 x G screw.
Pic 8: Fit pipe 41G to the end of the vacuum tank as shown.
Pic 9: Connect pipe 41H to the end of pipe 41G.
Store everything and all unused parts safely for now.
