Joined: 20/12/2011 Posts: 134 Points: 384 Location: barnoldswick
can somebody tell me which are the E type screws to the cockpit base onto the cockpit side as it says in mag 44
Joined: 27/05/2011 Posts: 256 Points: 774 Location: barrow in furness
It might just be me bein a bit daft but I thought in 1 of mags around that issue (couldn't say which without looking) but what the screw type said in the build guide was a different screw to the type mentioned in the "parts included with this issue" part. I know we doña always use the parts from that particular issue but I'm sure it said to use a type E screw for example but the picture showed a different (similar to) type c screw. Id check it against mr T's online build to make sure it's the correct one. I was at sea so didn't have Internet and wham reading that particular issue I got a bit confused! Besides that, type E are the small black screws, like the ones used to screw most of the rear suspension together! Enjoy! If at first you don't succeed........skydiving is not for you!
thanks for that il have a better look
