Rank: Pro Groups: Registered
Joined: 22/03/2010 Posts: 236 Points: 709 Location: Falkirk
Your right, the new ring look far better, I think I'd do the same now. Regards,
David
Joined: 06/04/2010 Posts: 58 Points: 133 Location: Newcastle uk
Changing the Anchor Ring !!
I decided to go for a large Anchor ring , After opening up the Anchor kit i to thought the ring looked a little small , I made a new ring so the old one fitted inside , that give me the perfect Dia . While i was busy I made up all Four rings together . All the photos and reference points have been a great help , I now check as many photos of Victory as i can , and will continue to do so before i assembly any of my Model of HMS Victory . Thanks to everyone on the forum for your amazing tips and reference points .
Joined: 25/03/2010 Posts: 100 Points: 289 Location: derby
how big is the new ring ?
Joined: 17/03/2010 Posts: 127 Points: 329 Location: cornwall/portsmouth uk
i remade the anchor ring this afternoon,to make it a bit bigger. i used the core of co-ax cable. which i stripped out and then bent into a circle around my knife handle. i will be doing the rest this weekend. probably putting the puddening on with fishing line and the seasing on with white thread. steve
The External dia is 14mm ,Ideal size for the scale of this Anchor
Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,051 Points: -13,308
Thats so much better, well done Mac:)
Joined: 18/04/2010 Posts: 21 Points: 63 Location: newcastle
The bigger anchor ring def looks alot better, think i'll be changing maine aswell. i'm glad I have joined the forum as i'm guessing there are going to be many modifications to the kit
Joined: 30/03/2010 Posts: 285 Points: 880 Location: Belton, Norfolk
Oh yes that looks alot better macmedal. Any idea what diameter is?
I wish I were a glow worm, A glow worm's never glum, 'Cause how can you be grumpy? When the sun shines out ya bum!!
Quote:The External dia is 14mm ,Ideal size for the scale of this Anchor
Fantastic work Mac, 14mm yes! I will do the same as you Cheers MWG MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 10/04/2010 Posts: 28 Points: 70 Location: cheltenham
thats better cap what did you use & how did you get it round?
Joined: 30/03/2010 Posts: 66 Points: 191 Location: Britannia
I used copper earth wire from lighting cable. I took a long strip and wrapped it around a circular object which was the correct diameter (approx 12mm internally) then cut it at the cross over point.
14mm external sounds about right for the 1:84 scale as Mckays book for 1/96 bower anchor is 12mm.
Joined: 26/03/2010 Posts: 146 Points: 473 Location: Plymouth
Macmedal What a brillant idea, copper wire, I'm impressed and will follow suit if you don't mind a little plagerism. ArtfulBodger Previous Build: HMS. Bounty
Joined: 25/03/2010 Posts: 472 Points: 1,357 Location: Hyde
Hi there I've just received 2mm rope from cornwall model boats. It is really nice but how to make it white? Tom
tom, the rope comes white from cornwall models, or bleach existing rope. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Well Mine came in brown ish colour so I need to bleach it I guess. What's the product code for this rope anyway? Thanks
