jonny7england wrote:No...Sorry but, I just can't seem to be able to post pictures? I must be doing something wrong somewhere? I write what I want to say and where it come to adding a photo, I put a tick in the box (attach files to post) then nothing happens?? I am at a loss as to what to do?? Hi As Chris mentioned you write your text. As you have done tick the add pictures box (i usually then tick the preview to make sure all the text looks formatted ok. You then need to POST and its at that point you get the selection box to add the pictures. Kind regards Tony Happy Modelling
I've been having all sorts of problems here, but with a bit of luck this time, problem should be solved? as he mutters cursedly under his breath "I hope". Here are a couple of pictures of what I have been up to.Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Very neatly done. Looks fantastic. What sort of glue did you decide on using for gluing the metal decorations to the wood please ? Tony Happy Modelling
Hi Tony...I used ZAP-O Foam Safe CA (Odourless} from Cornwall Model Boats. It is the only superglue that I can safely use as other products causes me to break out in all sorts of complaints as does the fumes...Been using it for a longwhile, good stuff!! Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Rank: Super-Elite Groups: Registered, Moderator, Tech Support, Technical Support, Forum Support Team, Forum Support USA, Global Forum Support, Global Forum Support Team Joined: 17/12/2013 Posts: 3,983 Points: 11,974 Location: NY, USA
you are certainly having ZERO problems with the build!!! Museum quality for sure.That stern ornamentation is stunning.
jonny7england wrote:Hi Tony...I used ZAP-O Foam Safe CA (Odourless} from Cornwall Model Boats. It is the only superglue that I can safely use as other products causes me to break out in all sorts of complaints as does the fumes...Been using it for a longwhile, good stuff!! I think i will give that a try. I am really not doing very well with my present brands. Building that hachette spitfire and sadly much of that is super glued together and i find the goue fogs and leaves a white residue. Thanks for the info - i will look that one out when i i next place an order. Tony Happy Modelling
Rank: Master Groups: Registered
Joined: 21/04/2011 Posts: 1,027 Points: 3,107 Location: Buckinghamshire
Tony
Cornwall Boats also do Pro-Can canopy glue which is supposed to be very good although I have never tried it myself. goddo attached the following image(s):
You may have been away for a while Jonny but what a stunning result you're producing. She's beautiful in every way and an absolute joy to see..... .. Great to have you back..... Regards Alan
Rank: Administration Groups: Registered, Forum Support Team, Administrators, Global Forum Support Team, Moderator, Official Builds Joined: 09/11/2012 Posts: 7,909 Points: 22,907 Location: East midlands
Hi Jonny Have to agree that you are producing excellent results. Keep it going. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hello my friends....I trust that you are all keeping safe and well? I have been trying to get in as much modelling as I possible can since that long stretch off my build, and each time I sit in front of my SOTS, I always find places on it where it could do with a little tweak here and there to improve what I had done ages ago..Is it me??? Anyway, I am only posting one picture on here today of my progress. I have been busy painting what seemed like an endless number of decorations while contemplating Issue 94 and the chainwales. and I was wondering...Has anybody used any form of reinforcement to secure the chainwales to the hull such as de-headed brass nails or something similar?? Thought I'd ask. Anyway, back to the grindstone, take care now and catch you anon... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Hi jonny, Another great picture of your build progress. You mentioned the chainwales and using de-headed brass nails. On a previous build that I did, the chainwales were thick enough that I could just use cut offs from cocktail sticks to use as dowels. Definitely helped. Obviously it depends on the thickness of the wood. Cheers Chris
Hi Jonny, Glad to see you back. I have just been browsing your diary and it's simply amazing Looking forward to your next update. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Hi Jonny, Decoration painting looks good to me. Keep up the good work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thats looking very good. And its a good point you make about just how bright the colours would have been on the original. Interested to see your take on this when its all done. Hope it all continues well Tony Happy Modelling
Another lovely update on your progress Jonny, coming along beautifully..... Regards Alan
Hi Jonny, Congrats on being the "Featured Build of the Month". I have awarded your "Green" medal which should show shortly. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Featured Build of the Month eh.... congratulation Jonny, the recognition is very well deserved for the effort and skill you've applied to your build.... Very well done..... Regards Alan
Overwhelmed/Stunned/Gobsmacked??? What an honor!! Thank you Model Space for bestowing this award of the green medal. I am more than grateful... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
