interesting build you have going on. she looks great I am interested to see how she develops. J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Rank: Pro Groups: Registered
Joined: 13/09/2012 Posts: 149 Points: 435 Location: Highlands of Scotland
I am not having a good day, here is the explanation that was to go with the pictures. My Mods so far trying to copy De Velde's and Payne's artwork, Increased the Foredeck height 4mm fore 8mm aft. Curved the forward Bulkhead. Moved the Bow Spirt to starboard. Raised the grating deck 6mm. Increased the Poop deck 2mm fore 7mm aft. Adjusted the canon port spacing and reshaped the entry port. Reduced the SternCastle overhang and Galleries 10mm. Raised the counter brackets to start between the lower and middle gun decks. Moved the Transom aft 10mm. Added the middle and lower stern chasers. Hull was given a second layer of planking of 6X2mm Walnut. The dry fitted Stern Castle planking supports was removed and the missing parts of the decks made for fitting as I progress up the hull.
Various balsa aircraft both rubber powered and RC Billing Jyland Billing Wasa Billing Dutch Royal Barge (gold medal winner Germany 1975) Scratch built HMS Victory using HMSO plans hull size 26" Scratch built Yamato Hull size 8'8" De Pardo HMS Bounty
Current build Sovereign of the Seas
Wonderful work Sandy She is looking mighty fine mate. Kind Regards Nigel
Thank you very much Jase and Nigel for you kind words. now the fun begins. Sandy
Looking great there Sandy, will be nice to see how you progress with her... Regards Alan
Gandale wrote:Looking great there Sandy, will be nice to see how you progress with her... Regards Alan Thanks very much Alan Sandy
while working at the stern I noticed that I would not have room for upper deck stern chasers due to all the bits and bobs of the stern construction. The only thing I could do is rip it all out. SandyM attached the following image(s):
Hi Sandy Had the same problem,I am back at it with the dremel this weekend.I have purchased one of every type of ornamental cannon Amati make.My decision is full carriages throughout.These cannons are so nice,they just have to be fitted . Kind Regards Nigel
NMBROOK wrote:Hi Sandy Had the same problem,I am back at it with the dremel this weekend.I have purchased one of every type of ornamental cannon Amati make.My decision is full carriages throughout.These cannons are so nice,they just have to be fitted . Kind Regards Nigel Hi Nigel, I agree they are very nice, I have decided on the 40mm (barrel 37mm) for the middle deck. I think the 50mm ( barrel 45mm ) is to heavy for the lower deck even on a smaller truck there for I am extending the 37mm barrels for main battery in the lower deck. Sandy
SandyM wrote:NMBROOK wrote:Hi Sandy Had the same problem,I am back at it with the dremel this weekend.I have purchased one of every type of ornamental cannon Amati make.My decision is full carriages throughout.These cannons are so nice,they just have to be fitted . Kind Regards Nigel Hi Nigel, I agree they are very nice, I have decided on the 40mm (barrel 37mm) for the middle deck. I think the 50mm ( barrel 45mm ) is to heavy for the lower deck even on a smaller truck there for I am extending the 37mm barrels for main battery in the lower deck. Sandy Hi Sandy The scale length of the 20 biggest cannons on the lower deck works out at 42mm long.I am not sure wether to go mad with internal detail as I have no intention of lighting.The biggest draw is the fact of the full barrel and that you will see the end of the carriage in the port.Struggling to find a true poundage for the largest guns,some sources claim as much as 60lb. Kind Regards Nigel
Hi Nigel, Yes I had thought of that ( my canon experiments) my solution was using the same trucks but extending the barrels this would cause the barrels to be off balance so I decided to drill out the barrels to the correct bore and make that end lighter. Not true scale I agree but the visual effect I think will match the artwork, I hope. Sandy
