Awesome job, wanna build mine now!!!
Hi Nem all I can say is thanks Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi All The railings have now been fitted, some transfers to add then some weathering and the crew to make a mess off regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Rank: Master Groups: Registered
Lovely job there Andy. Watching with interest. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Great job as usual Andy, another fine looking model from the 'arpurchase' stable!!
Well done and keep up the good work my friend!!
Kev
Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
Looking good there Andy.Hope you don't mind me asking this question it is not a critisim although may appear to be to anyone not reading it properly. Looking at the photo which shows the barrel end on,if you had to do it again would you have decided to paint the inside of the barrel so that the base plastic colour doesn;t show or would you have still left it au naturel? Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
Hi Hans, SMM and Rob Thanks for the comments and she has turned out a lot better than I hoped, I have ordered the shell transport tank from Trumpeter apparently there were 2 or 3 per morser to keep it firing but I will be using only 1 for my 1st dio. Rob your comment is perfectly ok and in hindsite I probably should have painted the inner gun barrel but in normal light and at normal angles it cant be seen unless you pick it up and stare down the barrel, the etch insert is about 2 inches deep and its the flash on the camera that lights up the inner barrel and makes it stand out like saw thumb so to speak. Again thanks for looking and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi All Muds been out again, I have tried to diminish it as it goes up the hull and put it where most foot traffic would be, not sure if it worked but im happy with it. The transfer's have also been applied also. The last two pic's show the Trumpeter loading tank that I will be building soon and its size compared to Loki also the two turned ali shell's are shown too that are included in the kit. As always all comments/questions are welcome regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 13/01/2012 Posts: 605 Points: 1,630 Location: Bucks
Turning out really good. The loader will make up a really dio HMS Surprise HMS Snake HMS Bounty HMS Royal Caroline HMS Victory rebuild HMS Supply
Hi Moriarty Thanks for looking in and yes the loader will certainly give a better perspective regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi All I needed more figures so I could have the morser and supply tank crewed properly for the dio, so after a little searching came across these, says it's for 'Karl but what the heck any crews a crew on a gun. Also there are some nice extra's in the way of equipment. I wont be using them all but it gives me some practice pieces to play with aswell regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
looks like a nice set - and as usual the men in charge are stood about doing nothing “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Things never change do they Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice work Andy
Hi Tom Thank you Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi All Made up 2 of the crew provided in the 'Loki' kit just to see how they turned out here they are with a coat of grey primer and yh its still wet regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Nem Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
This is the version I got to go with mine.
Hi Nem Lots of people doing the il stand around a give advice routine on there regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
