Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
Hi group I have just started this build and received the first 4 packs of parts. I have started to build the frame work as described in the instructions and have come across a problem. Frames 7 and 8 (which are identical) both have locating pegs at the bottom of the frames, however, the base to which 4 frame parts attach only has 3 sets of holes. Should I remove the location pins from frame 8 or drill location holes in the base to accommodate the pegs? thanks guys Riff-Raff You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
 Hi Riff Raff the two parts with lugs are part 8 the missing part without lugs is sent later I think in the next pack of 4 if you chop off the lugs and use it then it can affect the hull shape later on. hope this helps regards Andy Ps This problem with the hull formers has been mentioned in several build diary's and it was the same in Japan when it was 1st issued there Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 10/10/2012 Posts: 66 Points: 191 Location: UK
Hi there, I ran into the same problem and you must wait for the proper part. I decided to cut off the lugs only to find that I had to deconstruct the hull because it was misshaped. Patience will save you a lot of time. Dan Current Builds: Yamato On the Bench: Akagi, USS Missouri
Joined: 17/03/2013 Posts: 192 Points: 524 Location: United Kingdom
Hi It looks like that the problem with two No.8 frames has not gone away.I have just received my first issue and have the same and will have to be patient and hope No.7 arrives in the next delivery. Regards Taz. “Count your age by friends, not years. Count your life by smiles, not tears.”
Hi all Just to confirm that you do get replacement ribs in issue 02,I just received mine yesterday. Regards Taz. “Count your age by friends, not years. Count your life by smiles, not tears.”
