Rank: Pro Groups: Registered
Joined: 24/01/2010 Posts: 131 Points: 398 Location: North Yorkshire FILEY By The Sea
Joined: 08/03/2010 Posts: 19 Points: 37 Location: Crawley, UK
Hi Jinks,
Thats looking really good mate, will keep an eye on your build as I am not starting mine till i have all the parts as I still have a fair way to go on my bissy yet. As your going radio control how do you think this will be affected by the superstructure? As just from handling the metal parts I have they are mighty heavy and would think this would cause big problems with the ship capsizing?
Joined: 02/04/2010 Posts: 491 Points: 1,460 Location: Poole
That's a mightily impressive beast of a model! Still following with interest. Keep up the good work. Schnellboots on back burner
Tools.
Joined: 30/03/2010 Posts: 143 Points: 434 Location: cheshire
I'm impressed so far with your build its going to look amazing on the water when its finnished Alan
Not a lot happening just waiting for next lot of bits went to Kirklees Model Boat Club open day on Sunday at Wilton park Birstol and a good day was had Chatting and sailing if you are intrested in the photos folow this link http://www.modelboatmayhem.co.u.../index.php?topic=24358.0
Joined: 21/09/2009 Posts: 46 Points: 130 Location: Here
Some photos of the Kure museum 1/10 Yamato model which might help, also noticed that the edge of the wood deck is lined around its perimeter. Trawler attached the following image(s):
Thanks Trawler will look at the photo on Kure museum site a little closer but as you can appreciate their is a vast difference in scale and sum things are just not feasible on 1/250 the deck is one that is. Will modify my deck to incorporate the border should make it better
Keep up the good work and its looking good, the planking must have driven you to distraction
Not a bit found it rather satisfying must be a masochist at hart think the secret is not to do to much at once and go slowly do not rush ho and a good set of tweezers have a set the ends are very thin all most pin sharp at the ends can pick up very fine things with them
Rank: Master Groups: Registered
hi jinks8 could u give me a lead on where u got ure motors from can get reg size but noted yours are micro thanks
