Looking good Stu very neat work Kind Regards Nigel
Rank: Pro Groups: Registered
Joined: 06/12/2012 Posts: 152 Points: 439 Location: Barrow-in-Furness Cumbria
NMBROOK wrote:Looking good Stu very neat work Kind Regards Nigel Thanks Nigel, i appreciate your encouragement. Cheers Stu
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
lovely work stu! Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
Admiral Anti Spiral wrote:lovely work stu! Thanks Admiral i appreciate your comments as always. Cheers Stu
very nicely done Stu, planking looks great and much better than pointy planks.... ..Keep up the good work.... Regards Alan
[img] http://i1333.photobucket...040_zpsc5586d15.jpg/img]Hi All i have only just started back on the model after 7 months off. work and stuff took over. but now I've finally finished the second layer of planks and had a sand down. I'm still undecided how to finish the lower either paint white or stain. I'm not sure of the finish. any thoughts would be much appreciated. Well back to it now, so I've got a challenge to catch up. Cheers Stu
Beautiful planking job, one of the best I have seen This is going to be a stunner, well done! Steve
thanks Steve. i appreciate your comments. Cheers Stu
Looking fab Stu.... .. For me, would have chosen a darker wood for the second layer, stained then varnished.... As you have a very light wood then make sure you do plenty of test pieces to see how the stain will look... only then can you really decide whether to stain or paint.... Hope this helps... Regards Alan
Thanks Alan Think ill spend the weekend doing some samples. Cheers Stu
Hi Stu One idea would be to try a lime wash this will whiten the wood and then a coat of clear varnish. Just an idea regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks andy ill add that to my trial list. Cheers Stu
Hi stu. Very nice clean build. Look forward to seeing your progress. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
thanks Ian and thanks for looking in. Cheers Stu
