Top class work as usual Andy, looking fab....
Moving along nicely Andy, you must be very pleased with this one, if only I had the space for one of these....and the money....and a very understanding wife Steve
Hi Alan Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Steve Yes I wanted this one for a good while but waited till I had finished one subscription before taking it on unfortunatley its now out of stock to new subscribers but im so glad I got it now, excelent part's that fit straight on with the minimum of preparation and instructions that are like the D51 clear and precise. With the added bonus of the electric engine pack that sounds amazing it just puts the cherry on the top. Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, you build is looking great. You are at exactly the same stage as me.
Hi Graeme Thanks for looking in and your comments and yes I had noticed that were both at the same stage regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi All Some more progress made the left wing is more or less compleate apart from the ailerons the wheel wells are now in position, the flap has been added, the folding wing tip fitted and finally the upper wing skeleton skins. Still have some right wing ribs to make up, engine baffles to add and the lights to be added to the cockpit along with some strengtheners more soon regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good.. Regards Alan
Rank: Elite Groups: registriert, Registered Joined: 20/03/2011 Posts: 2,356 Points: 7,122 Location: UK
It's looking sweet Andy... ... Once I have a few more packs I'll think I'll make a start on mine Spencer
Hi Spencer Thanks for looking in and your comments, I bet those fingers are itching to get started regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi All The cylinder head baffles have been painted and added to the heads also the four ribs provided this month have had there braces added. Finally for this month the cockpit bracing's have been added along with the two LED lamps situated in the cockpit area. regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Rank: Pro Groups: Registered
Joined: 27/06/2011 Posts: 434 Points: 1,309 Location: milton keynes
coming together nicely Andy dan Built - MP4/23, Zero, Deagostini Falcon, Model Airways 1903 Wright Flyer, Senna Mp4/4. Working - Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4 on the bench, Model Airways Sopwith Camel.
Hi Dan Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi All My parts were delivered this morning and in a cardboard box by far an improvement on the jiffy bags. The final ribs have been made up then temporarily fixed in place and the aileron/flap bulkheads fitted. The folding wing tip has been made along with the fuel tank and rib spacers fixed on it. All I have left is to paint the oxygen bottles and gun then add the valves. More soon regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
As usual, looking good Andy.... Regards Alan
Hi Alan Thanks for looking in regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking sweet Andy Spencer
Hi Spencer Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi All The cylinders have been made up and painted the last thing done here was to add the 6 valves to all of them, then they were attached to the fuselage. The wing 20mm cannon has been made up and painted. That concludes this months parts ,more soon regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
