 Hi All More progress made. The distributor ring has been added to the front and the oil pipes added to the rear ring of cylinders the front rocker boxes and valve stem covers will be added in one go like I did the rear set. Some chipping has occured around the engine but it looks quite realistic to my eye. The second wing is well on the way to construction im not painting this one as it will be skinned. The front fuselage is now being put together, the two halves joined and the various formers added as instructed, also the machine gun fired shells chute has been fixed after the machine guns had been added. Lastly the lower rear fuselage cover has been glued in place. This concludes pack 6 regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good Andy and the chipping does add to the realism
 Hi Spencer Thanks for your comments much appreciated regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Small update on pack 7, I have added the flap and aileron bulkheads to the wing. I also made up the metal parts some of which benefited from some filler more soon regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Didn't realise you were building this one Andy....  .. Another great piece of work, looking good.... Regards Alan
 Hi Alan Its unlike you to miss anything  thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Hi Alan Its unlike you to miss anything  thanks for looking in and your comments regards Andy  .. Especially your builds....  .. As I think the quality of your work is superb and members can learn so much from you.....  .. Regards Alan
 Hi Alan thanks for the kind words regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All I have finished mounting the gas bottles , oil tank and various bars to the forward fuselage. The fuel tank was then made up and painted with aotake , one word of advice here the tanks are made of very thin aluminium and will not stand much in the way of tidying up with files ect so when glueing together the maximum in accuracy when lining the two sides up saves a lot of fettling with a delicate piece of metal later. Finally the instrument panel was painted up and the dials and lenses added. the painting is a little tricky in parts due to size and small gaps. Another change I made here was to the central dial , the printed dial was ready to be used but below it is a yellow strip which is also part of the instrument but this is not pre cut, I cut this piece out and added it to the panel. If you look at the picks a red arrow and circle will tell all. Lastly on the clear plastic parts that are left over for future use the reflector sight [ circled red] was broken so I have ordered a replacement. This concludes pack 7. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The three lights have been added to the wing as has the fuel tank the light to the instrament panel has also been added. All the rocker boxes have now been added as have the push rod tubes Still more to come regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, you are going from strength to strength with this model it is not only look the part but skilfully built watching with interest. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Looks fab Andy J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Hi Trev thanks as always for your comments and observations ,always appreciated regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Jase Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks fantastic Andy, such a good partwork this one, real quality. Steve
 Hi Steve thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All some more progress, The oil pipes have now been added to the second set of cylinders. More ribs made up with there bracing struts. The instrument panel has been fixed in position as have the fuel/air mixture lever, pitch control lever and the undercarriage lever. I am still painting the bits for the undercarriage oleo legs but will update as this is finished regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Finished making up the oleo leg and fitted the mounting/pivot block to the wing lastly the wing machine gun was mounted in position in the wing. This concludes pack 8 so more next month. regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
coming together nicely Andy Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
 Hi Dan Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (19)
