Joined: 28/09/2012 Posts: 29 Points: 67 Location: telford shrops
hi,coming to the end of the planking,but i can only fit 1 50mm length strip at the end of the hull step 15/16 will this matter later on in the build ,would appreciate some advice thanks val
val ellams wrote: hi,coming to the end of the planking,but i can only fit 1 50mm length strip at the end of the hull step 15/16 will this matter later on in the build ,would appreciate some advice thanks val Hi Val, It`s my opinion that as long as you have the ribs covered and none of the tops uncovered you should not have any issues. Most probably occured if you have had a few wider planks than normal. My second plank was only needed for a very small part to cover the rib tops. Hope this helps. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
thanks for your reply very helpful,all ribs are covered ,your probably right about the thickness of the planks,have a great 2014,  val
 Rank: Pro  Groups: Registered
Joined: 30/08/2012 Posts: 336 Points: 857 Location: London
Yeah, seconding what Del Boy said. I only had room for about a plank and half at that stage. As long as it covers the ribs and is level with the stern gallery, you are good to go.
Hi Val, agree with Derek. Just make sure your planking goes above the ribs, later in the build you will be cutting them back anyways but you need to ensure you have enough height on the bullworks first..... Regards Alan
 thanks all for your advice ,just waiting for a dry day to start the sanding ,hope you all have a great 2014. val
