162 Pages «<113114115116117>»
#2281 Posted : 03 February 2014 23:00:57
stevie_o wrote:
Beautiful work Alan, I was looking at the build pics of this on the main DeAg site today, unbelievable how many decorations you have to cram into that stern, looks amazing though.
Thanks Stevie, appreciate your looking in and comments..... You are correct, there is an unbelievable amount of decoration to cram into not only the stern but also along the sides of the hull and on the prow..... Cool Cool .. I also have other ideas for the deck areas but am not doing anything in that area until later in the build.. possibly casting some items when I get the casting kit I am looking at.... Cool Cool Will keep you posted....
Marcel
#2282 Posted : 04 February 2014 13:54:07
BigGrin
I was considering using wood instead of paint on my ship's hull. Looking at your build, you have convinced me to go on with this plan. I am still in search for altemrnate wood to replace the red paint strip.
I admire your work, Alan. I am curious about the rest of your build.
Marcel
Sovereign of the Seas
#2283 Posted : 04 February 2014 22:31:33
Marcel wrote:
BigGrin
Marcel
Thank you very much Marcel for the very kind comments.... I pondered for a long time over painting or going with walnut veneer and now it is done I in no way regret the decision....Cool Cool .. Hope you find your alternative to the red strip, I decided to paint this part and am happy with the results....Cool Cool .. Will be following with interest to see how your second layer will look in the end..... Cool Cool
Thanks again....
Sinbad
#2284 Posted : 08 February 2014 13:32:29
Turquoise Medal: Turquoise Medal for model making know-how contribution
Very interesting to see how you guys have to punch out your parts. Here in New Zealand we get loose parts. I guess this saves a lot of waste wood (and some trees) but it could also explain why there can sometimes be missing parts.
#2285 Posted : 10 February 2014 22:21:19
Hi Sinbad, have to cut out the parts from the frets and I like it this way as it helps to prevent breakages... In all the issues I have received I think there have been 2 with a part missing but other than that I think the quality is nothing less than superb.....Cool Cool
#2286 Posted : 10 February 2014 22:34:24
Hi all, issue 75 complete now.. Started by fitting the decals onto the brass etch shields, these were attached using Micro Set and superglued to the stern gallery. Coat of clearcote added for protection..Cool Cool
Cut all the pieces for the forecastle gunwales from the fret and cleaned all the edges carefully using a fine file.... Stained using 3 coats of walnut stain, and painted some parts using the same black and burgundy used on the hull... Cool Cool .. Uprights were cut slightly longer as I wanted to ensure a smooth line all the way round the forecastle.. these were sanded down gently to get the correct heights. Uprights were stained using medium oak...Cool Cool . Once attached, used some wood filler to smooth out the deck line that could be seen on the outer hull and sanded smooth... Moved onto drilling and cutting the 4 gun ports on the bow bulkhead, this was done starting with a 1mm drill, a round reamer and a piece of dowel with a fine grade sandpaper attached. Finally applying a matt varnish and touching up where needed.... Am very pleased with the way it all turned out....
NMBROOK
#2287 Posted : 11 February 2014 00:03:47
She is coming on great guns Alan,fabulous workCool Cool
Kind Regards Nigel
#2288 Posted : 11 February 2014 00:10:15
Kind Regards Nigel
Thanks Nigel for your very kind comments..... So good to hear from you again and hope all is going well for you..... Cool Cool .. Just in case you haven't noticed, I have now started building the Mantua's Titanic and am finding it quite an enjoyable challenge..... Take care and hope you keep popping in from time to time....
KobusBeukes
#2289 Posted : 11 February 2014 07:14:26
Hi Alan
Fantastic work there! Your attention to detail is great.
Keep up the good work.
Kobus
Current Build
#2290 Posted : 11 February 2014 21:59:38
KobusBeukes wrote:
Hi Alan
Hi Kobus, thanks for looking in and your kind comments....Cool Cool
der Gohfelder
#2291 Posted : 11 February 2014 22:14:21
Hi Alan!
Extremly nice like always! It would be a hard job for me to follow you!!!!
Regards, Bernd
#2292 Posted : 11 February 2014 22:51:34
der Gohfelder wrote:
Hi Alan!
Regards, Bernd
Thanks as always for commenting Bernd, always appreciated....Cool Cool As for following me, remember I have seen your SOTS build on your German forum and I think you are doing a stunning job... love the colour scheme and the finish you have achieved..... Will drop into it again when you next update.....Cool Cool
Best regards
#2293 Posted : 12 February 2014 10:20:03
BigGrin Lovely work Alan looking good BigGrin Rgd Martyn
#2294 Posted : 12 February 2014 10:21:09
#2295 Posted : 12 February 2014 13:23:17
Hi Alan.
Looking superp IanCool Cool BigGrin
#2296 Posted : 12 February 2014 13:49:45
Beautiful job there Alan, she is really looking good. Well done.
#2297 Posted : 12 February 2014 13:54:56
#2298 Posted : 12 February 2014 22:56:15
Thanks for the nice comments Martyn, appreciated..... Cool
#2299 Posted : 12 February 2014 22:58:01
ian smith wrote:
Hi Alan.
Thanks for the kind comments and for taking the time to look in Ian, appreciated.... Cool Cool
#2300 Posted : 12 February 2014 22:59:15
Thanks for your very kind comments Hans, took a few tips from your build....BigGrin BigGrin
Guest (10)
This page was generated in 0.475 seconds.
