3 Pages 123>
My next build a Lanc's B1 Options
Allen
#1 Posted : 04 March 2014 21:46:43
Hi to you all, Just a quick note to let you know that as I can not do any more work on my Mozzy until the summer I've have sorted out my next small project Laugh I found the plans for a LANCASTER B1 'SPECIAL'
It has a wing span of 8'4". body length 6'. it will be powered by 4 electric motors but that will only give a flying time of around 7 min's so I might play around to see if i can put a motor in with gearing to the props to try and give a longer flying time. Air pistons to operate the under carriage. A lot of the parts are hand made but there's a lot that can be found in the modeling shops so not as much head scratching as I've had with the Mozzy.
So first thing fist is to clean up my work station and then make the jig for the body. but when it come to the wing it looks like they will be built in the lounge as the wing are built as all in one. It a good job I live on my own as any partner would object me thinks. BigGrin
As soon as the jig is made I'll start to post photos so you all can see how thing progress.
Allen
#2 Posted : 04 March 2014 22:14:05
Allen
#3 Posted : 04 March 2014 22:57:42
Steve I hope it will be easier than my Mozzy but bigger.
#4 Posted : 04 March 2014 23:48:05
This is going to be some build you are embarking on.... look forward to seeing how you progress with this one.... good luck with her...
Allen
#5 Posted : 05 March 2014 18:04:24
Well I've started with the easy bits first. I've just made the jig for the main body for the Lanc's which is just over 6' long.
I've also stated to make the copy's of the main frame work to body and wing spars by photo copying the parts onto card and then laminate then before cutting out ready to draw around. Doing it this way makes them a lot firmer to draw around plus they can be wiped clean and used again if needed or given to anybody else that would like to try to build the Lancaster B1 when I've finished.
Lancaster B1 001.jpg (907kb) downloaded 93 time(s).
Lancaster B1 003.jpg (922kb) downloaded 71 time(s).
Lancaster B1 004.jpg (908kb) downloaded 61 time(s).
Lancaster B1 006.jpg (899kb) downloaded 61 time(s).
Lancaster B1 007.jpg (911kb) downloaded 64 time(s).
Lancaster B1 009.jpg (891kb) downloaded 78 time(s).
Allen
#6 Posted : 11 March 2014 12:27:05
Hi all well as you can see thing are progressing with my Lancaster and its starting to look like a Zeppelin at the momentBigGrin there still alot to do as to the fuselage frame. but I have to wait until my local model shop get some more balsa wood in as I cleaned him out.
I'll get up dating as the build progresses.
Allen
Lancaster B1 011.jpg (331kb) downloaded 67 time(s).
Lancaster B1 014.jpg (284kb) downloaded 63 time(s).
Lancaster B1 015.jpg (295kb) downloaded 57 time(s).
Lancaster B1 016.jpg (343kb) downloaded 77 time(s).
Allen
#7 Posted : 15 March 2014 13:08:59
Hi all, Well I've done part of the tail which is made with from 1/8" and 1/16" balsa. It was a bit tricky as it all had to be made flat as you all know that working with light balsa it can twist very easily.
The front gun turret was taken out to make the Lancaster lighter so it can Carrie the large pay loud and was replaced by a dome which in this model is made from 3/8" balsa hollowed out.
the rear gun turret base is made from 1/2" balsa also hollowed out.and when the Lancaster is finished it should weigh it at around 9 LD.
Lancaster B1 049.jpg (320kb) downloaded 69 time(s).
Lancaster B1 048.jpg (331kb) downloaded 53 time(s).
Lancaster B1 050.jpg (337kb) downloaded 59 time(s).
Lancaster B1 052.jpg (328kb) downloaded 58 time(s).
Lancaster B1 053.jpg (324kb) downloaded 51 time(s).
Lancaster B1 055.jpg (293kb) downloaded 48 time(s).
Lancaster B1 056.jpg (326kb) downloaded 62 time(s).
#8 Posted : 15 March 2014 13:34:22
Fantastic Allen, very interesting seeing this come together, this is real modelmakingBigGrin
Can I suggest though that you actually place your pics in the diary and not as attachments, this way everyone will see the pics right away without having to click on them or download them.
There is some info here on how it's done - http://forum.model-space....aspx?g=posts&t=244
You will get plenty of comments and followers then as some people just don't like clicking links to see the pics.
Cheers
#9 Posted : 16 March 2014 11:37:40
Great start Allen. It looks a similar content to the Tony Nijhuis kit which is a nice build.
Congrat's on your first medal Cool
Allen
#10 Posted : 16 March 2014 18:36:15
Lancaster B1 049.jpg (320kb) downloaded 53 time(s).
Allen
#11 Posted : 17 March 2014 09:02:18
Hi All. Well here goes to try to put pic's on following Steve's Idiot instruction. I'm one of thoughts people that can even get idiot instructions wrong.
So I'm putting up pic from start to ware I am know.
Yes It worked I'm over the moon that it worked.
Allen attached the following image(s):
#12 Posted : 17 March 2014 13:31:24
Looks like a great start, nice to see something different on the Forum again. Keep the pics coming.
Allen
#13 Posted : 17 March 2014 18:52:37
Hi everyone Well it took me some time to work out how to put pic's up and that was with the help of Steveo. This Lancaster B1 will be build from plans so I try to build ever thing by hand so there is a bit of head scratching at times as I try not to buy from Hobby /craft shops if I can help.
At the moment I'm working out how to build the rear wheel Assembly as it has to be built into the rear wing and main body at the same time.
Pic's will follow soon now I now how to post them.
Thanks to Steveo for the link and help on how to post pic's.
Allen
#14 Posted : 17 March 2014 18:56:25
Allen
#15 Posted : 18 March 2014 20:29:33
Hi Every body. well to keep you up to date I've reinforced the part of the body ware 2 sero's will go and some of the electrical bit will live. Also put in the reinforcing bracket were the main wing will be attache to the main body.
I've also built the rear wheel from scratch from brass which will be attached to the rudder push rod so it can be steered when it on the ground. There still a bit of tinkering to do with it but that can be sorted out when the Tail wing is fitted as I need to ever thing sit's. at the moment I've made a small frame for it so I can make sore it will fit into the main body and wing assembly.
The tail wing is my next part to build so it might be a day or so before I post pic's of the wing as it's being built.
Allen
#16 Posted : 18 March 2014 21:00:49
Sorry about some of the pic's. I done now what happened I'll take some more pic's tomorrow and hopefully they will come out ok .
#17 Posted : 18 March 2014 22:16:42
Hi Alan,
See your well on your way for a great build,I will be following with interest.
Trev.
#18 Posted : 18 March 2014 22:40:35
Great work Allen, she certainly is going to me monster when finished.... Would love to see this one take to the air... Cool Cool .. Keep the pics coming....
Allen
#19 Posted : 19 March 2014 11:50:50
HI All. as promised I reloaded the pic's that did not come out. the pic's are of the rear wheel all had to be made by hand but there is still a bit of work to be done but to Finnish it off which can be done when it come time to fit the wheel to the main body and tail wing.
Allen
#20 Posted : 25 March 2014 18:44:09
Hi every body. Well its been a will so for an update on my Lanc's.
At the moment I've finished the tail wing with Rudder and elevator and rear wheel all attached to push rods.
There has only been one small hick up and that was nearly setting fire to the tail wing when I drooped the soldering iron onto the wing. All is well as only a small scorch mark on the wing and luckily it inbound so it can not be seen when the skin of the fuselage is put on.
All I need to do is attach the 2 push rods that run though the wing to the rudder and then glue the wing in place.
Guest (20)
3 Pages 123>
This page was generated in 0.262 seconds.
