Balsa Infills Options
Tanna Ted
#1 Posted : 30 March 2014 04:41:12
Hi everyone,
Are the balsa infills necessary Confused I don't see in Mr T's build diary.
Ted
______________________________________________________
Current Build: HMS Sovereign of the Sea
George1
#2 Posted : 30 March 2014 06:43:42
Hi Ted
Balsa infills just make it a little easier when it comes to planking later. With the infill there is no room for a plank to depress anywhere between rib frames. karl1113's build which I have been following shows a full infill however it is not mandatory as per the build instructions like you've seen. Just makes it a little easier for a newbie to ship modelling like me.
George1
Building HMS SOTS
Tanna Ted
#3 Posted : 30 March 2014 07:12:15
Hi George,
Thanks for the response. As I have never done this sort of thing before is there a place I can look at on how to do this. Al new to me.
Ted
Taz
#4 Posted : 30 March 2014 07:27:40
Hi Ted
If you read through some of the members builds then you will find how to put the infills in. Thats how I have started my build and I have found that it works a treat, it helps give added strength to the ribs and the framework , also the planks bond to the balsa.BigGrin
Best regards
Taz
Taz
#5 Posted : 30 March 2014 07:38:25
Hi Ted
I have found MWG's Build the Sovereign of the Seas, If you go to page seven, Mike has shown how to use infills.
TazBigGrin
Tanna Ted
#6 Posted : 30 March 2014 07:47:36
Hi Taz,
Thanks for yor reply. Dumb question but how do if the build diary Blink
Ted
#7 Posted : 30 March 2014 08:12:57
Tanna Ted wrote:
Hi Taz,
here you go, probably worth you having a look at the other members build diaries as everybody does things slightly differently.
http://forum.model-space...aspx?g=posts&t=4749
Tanna Ted
#8 Posted : 30 March 2014 08:48:30
Hi Jase,
Thanks for the link, appreciate it
Ted
#9 Posted : 30 March 2014 10:05:23
BigGrin Hi Ted
Infills are a good measure to help with planking for people new to building ships and give more surface area for the planks to adhere to more so at the bow and the stern where the main curves are.
I like Mr T rarely use infills as with confidence and experience the fairing of the formers is enough but take a look at my Santisima Trinidad build where you will see an example of the use of fillets and there placing to get the planks to lay correctly.
http://forum.model-space...aspx?g=posts&t=7623
Hope this helps
Tanna Ted
#10 Posted : 30 March 2014 10:43:55
Hi Andy,
Thanks for the link, I will have a good look at it.
Ted
bb1949
#11 Posted : 02 April 2014 15:43:10
Message is for TAZ. I am having trouble locating MWG' s build article which I understand includes infills. I am interested in that process and what like to how someone has done it. Can you tell me where I could find it please?
#12 Posted : 02 April 2014 17:17:57
BigGrin Try this link go from post #233 the bow was done earlier it will be a case of going back till you find it
http://forum.model-space...sts&t=4749&p=12
#13 Posted : 02 April 2014 21:22:13
Hi Guys, I also covered the process of balsa infilling the hull and you can follow the process from page 3 of my diary. Link to my diary index is under my signature block... This may also help you see the way it has been done.... hope it helps...
bb1949
#14 Posted : 05 April 2014 04:06:32
Hi arpurchase and thanks for the tip. I found what I as looking for on page 7 and have been progressing from there. I also found it is a lot easy to read the diaries with the desktop as opposed to the ipad, (which has it uses). I will follow up on Gandale's link after this note. Thanks for the help.
PS just been to Bunnings and bought its stock of balsa! Well the big bits anyway!
#15 Posted : 05 April 2014 08:39:38
BigGrin NP glad to be of help diarys can soon disappear into the less read areas and make them hard to findCool
Taz
#16 Posted : 05 April 2014 09:54:01
Hi bb1947 Sorry for not answering your question but have been away for a few days. Good to see you had help in answering your question.BigGrin Taz
9
Shaky
#17 Posted : 17 April 2014 16:25:49
Huh,
Balsa infills? I'm only up to issue five and have had to go and look back to old Blighty to find out what you were talking about. I have decided I will take the build in my time and just look occasionally at these posts.
Talk about nearly scare me off!
Shaky
#18 Posted : 17 April 2014 17:13:13
Hull infill's are are mentioned here..
http://forum.model-space...aspx?g=posts&t=5620
Shaky
#19 Posted : 20 April 2014 16:49:11
Okay, I apologise, but I thought I was on the Australian Forum so I did not expect to have to pre-empt the build and go elsewhere to find out what I have to do in the future!
Cheers and lets hope the Australian Forum stays at the build level we are at! After all, we are only Colonials!BigGrin
