Joined: 08/03/2011 Posts: 65 Points: 187 Location: Bendigo Australia
I read in one of the forums which I can,t find, that they added weights to the hull to stabilize it and not be top heavy. Any thoughts? Previous builds Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour http://jockspage.webs.com/
Hi Jock Some people have done this, not me personally though. My Victory even off the stand with masts on is not inclined to tip over. I guess it's up to you really. Steve
Joined: 05/10/2012 Posts: 68 Points: 114 Location: suffolk
hello Jock check out the build discussion page 8 theres a thread there titaled ballasting ideas from captain david dated 7/3/2013 jethro
Thanks for the link. I'm adding some red gum pieces between some of the frames, this should add some stability when rigging is completed, don't forget these ships carried ballast not only to keep the vessel upright in the wind but also to counter balance the rigging. Previous builds Bounty, Cutty Sark, Red Baron Triplane, Bismark,Titanic,Endeavour http://jockspage.webs.com/
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
Considering the weight of the hull (Frames, decks, cannons, and other parts) compared to the weight of the rigging (a few dowels and blocks) I don't think the need for ballast is something that I would consider. All 6 of the tall ships I have built stand perfectly stable. You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
Just to add.... The weight of these ships when just moving them about for dusting etc can be quite considerable in them selves. You do not need a parachute to skydive. You only need a parachute to skydive twice.
Hi Jock, I'm well into this build and have got to issue 99... Have to say, apart from the balsa infills I did I have applied any other ballast... so far she is stable in her cradle and quite weighty.... Don't see any need to weigh her down further....
