27 Pages «<89101112>»
George1 Build Options
George1
#181 Posted : 18 May 2014 03:40:23
karl1113 wrote:
hi, no that particular infill,was a mistake by the builder, he ended up removing it(I think)
Hi Karl. BigGrin
Thank you for letting me know that. It is greatly appreciated. Cool Cool
It's really great to have you guys looking in and able to give us Newbies advice from lots of experience. Cool Cool
George
Building HMS SOTS
George1
#182 Posted : 18 May 2014 03:47:02
George1 wrote:
Hi Alan. BigGrin
Appreciate you looking in and your input on this query.Cool Cool
From the pic you supplied I can't see any reason to infill the Bowsprit.
There looks to be "Bling" to go right where bottom of balsa infill would be in the way.Confused
I'd guess and say any balsa infills in Bowsprit would as I guessed be only necessary to stop any warp while waiting for fitting and not needed otherwise. BigGrin
You have enlightened me on this so thanks again, it's greatly appreciated and will save some unnecessary work. Cool Cool
George
Hi George, you are spot on.... There is no need to infill this section but I would recommend you store the parts flat until needed and not put them together until you get to the stage of actually fitting to the bow..... Keep doing what you are doing, you are doing a great job..... Cool Cool .. Will be following your progress with interest.... Cool Cool
Hi Alan. BigGrin
Thanks for your kind comments and even more your help in this matter. It is as always greatly appreciated. Cool Cool
we're lucky to have you guys with experience to guide and answer queries. Cool Cool
I'd be very happy for you to look in anytime and give advice as it will certainly make my work easier knowing I'm on the right track. BigGrin
George
Building HMS SOTS
George1
#183 Posted : 22 May 2014 08:02:50
Issue 11 came this morning now put together.
First Decking.
First pics dry fitted. Later pics gluing in place as I want to infill with balsa and waiting on issue with nails will put me behind when 2nd. decking comes.
Last pic the now tedious job of gluing rib frames now in correct position.
George
Building HMS SOTS
#184 Posted : 22 May 2014 11:09:44
Great work there George...Now that you have got some decking on, I found that the ribs are very fragile at this point before the planking is applied. I discovered to my horror when the model was upturned to fit the garboard planks...three of mine snapped!! I since used polystyrene packing especially around frames 15, 26 and 27? She's really coming along nicely George, well done mate!!
George1
#185 Posted : 22 May 2014 11:46:37
Hi Jonny.BigGrin
Thanks for looking in and kind comment, much appreciated.Cool Cool
Yes I can see the rib frames you mentioned being somewhat of a problem when ship upside down. I'm currently doing a full infill with balsa and for the moment I've got the largest/highest rib frames off end of table but I'm going to run into trouble other side when I do it because table hard up against the wall that end. I will do as you have suggested re the polystyrene. I did snap one side of a rib frame early in the piece when I was trying to get stuck braces off so could cut to shape. Lucky the break was nicely shaped so glued back as good as new but like you warned I am watching those high ribs all the time.BigGrin BigGrin
George
Building HMS SOTS
John Passmore
#186 Posted : 22 May 2014 12:31:33
Publisher Medal: Featured Build of the MonthOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Hi George
Further to my last post (no.25), I'm not going to infill the bowsprit or the stern gallery - I can't see the merit of it. I only have these parts dry fitted so far as is the lower deck so now I'm going to get cracking on the hull infills.
I am still trying to nut out how to safely immobilise the ship whilst it is upside down for the planking, once all the infills are in place. I'm not sure if polystyrene is strong enough. Frames 22 and 26 are the main worries - the tops of these ribs need to be off any surface.Confused
I'll keep you posted mate.BigGrin
JohnP
George1
#187 Posted : 23 May 2014 02:36:59
John Passmore wrote:
Hi George
JohnP
Hi John.
Read Alan's reply to your query your thread re mast sizes for doweling. Cool Cool Thanks Alan Cool Cool
As far as infills Bowsprit there certainly is no need to infill unless you're worried that warping may occur till fitted and even then only temporary as "Bling" later goes right between the ribs.BigGrin
A few have used the polystyrene and others the doweling to protect rib frames when upside down so it's a choice. I think the easiest is doweling to suit mast holes on a base board. However I'm always prepared to accept other advice. BigGrin
George
Building HMS SOTS
#188 Posted : 23 May 2014 09:31:55
BigGrin Hi George
Looking good, the dowel idea is about the best and simplest way forward as it will hold the ship rigid and be easy to work on.
There are a number of jigs built by the Victory builders to do just what you want here's one I found, link below, scroll down to post # 52 this could be adapted quite easily to suit your needs.
http://forum.model-space...osts&t=1911&p=3
George1
#189 Posted : 23 May 2014 15:04:39
Hi Andy.BigGrin
Thanks for kind comment appreciated. Cool Cool
Looked at the build URL and found "Jig" very interesting. Quite a simple idea but looks very effective. Certainly not hard to make. Cool
Because in use the deck sits/rests on the clamp boards and is held rigid by a rib frame each end it's probably even more stable than doweling on base board. BigGrin
Thanks again. Your input on this greatly appreciated. Cool Cool
George
Building HMS SOTS
#190 Posted : 23 May 2014 16:31:34
BigGrin Hi George
Not at all just doing my bit so to speak, there is another simpler jig that is good for angling the ship at about 45% from the perpendicular but I have to find that one still not as good as the previous jig but good for working on the hull
bb1949
#191 Posted : 24 May 2014 01:33:08
Hi George. Been a busy week for me. Lots of clients and working late. Yes I reordered issue 8. I will keep both skiffs one for the ship and one for ron. I enjoyed the discussion on securing the hull for planking and thank you for generating that discussion. I am off to Bunnings buy the materials to build the jig Andy mentioned. I put my deck on last night and everything went very smoothly. Ribs at right angles, keel line is straight, mast holes are round. True bliss!
Photos on my link later today.
George1
#192 Posted : 24 May 2014 03:05:36
BigGrin Hi George
Hi Andy. BigGrin
Will keep my eye out for that one when you find. Cool Cool
All are handy to know for different wants and needs. BigGrin
Thanks again. Very much appreciated. Cool Cool
George
Building HMS SOTS
George1
#193 Posted : 24 May 2014 03:10:34
Hi Brex BigGrin
Nice to see you back. I was wondering where you'd gone. BigGrin
Looked in your build thread. All coming along very nicely. Cool Cool
The info on the ink stains also very interesting thanks. BigGrin
Yes I think that "Jig" Andy mentioned will do the job nicely. There's lots of work later on the hull and the need to be upside down to do it.BigGrin
George
Building HMS SOTS
MichaelKan
#194 Posted : 24 May 2014 15:38:56
Rank: Amateur Level 1
Hi George,
Your work is really meticulous and premium quality. It's great to see many build designs and getting great ideas and tips off everyone.
Michael
George1
#195 Posted : 24 May 2014 16:42:52
MichaelKan wrote:
Hi George,
Michael
Hi Michael. BigGrin
I don't know about meticulous but I do appreciate your comment. Cool Cool
Yes, everyone probably has a little different idea in mind as they go and some of the more experienced builder's threads are definitely worth looking at in that regard. BigGrin
George.
Building HMS SOTS
George1
#196 Posted : 24 May 2014 16:47:39
Hull infill. One side done for now. Gonna' need to purchase more balsa before totally finishing other side. Thought my stack of balsa was enough, but surprising how quick it gets used up.BigGrin
Have left slot recesses in position for angle brackets as I want to use the base board as long as possible. BigGrin
Can't do no more at stern till next rib frame comes and I know the angle. Will probably have to sand more that end anyway. BigGrin
George
Building HMS SOTS
#197 Posted : 24 May 2014 17:18:56
George1
#198 Posted : 24 May 2014 17:28:22
stevie_o wrote:
Very nice work George, you should find the planking so much easier now you have the in-fills done. Looking goodBigGrin
Hi Steve. BigGrin
Thanks for looking in. Cool
Your comments very much appreciated.Cool Cool
Anything to make the planking easier later is certainly worth it. BigGrin
George
Building HMS SOTS
#199 Posted : 25 May 2014 00:55:06
Nice looking work George, very well done.... Think you will now find the hull feels very solid plus the added advantage of doing the infills is you can now see clearly how the hull profile will look..... Cool Cool .. Keep the pics coming....
bb1949
#200 Posted : 25 May 2014 02:03:11
Wow! You have moved on! Well done! I intend to do the infills as well over the next two weeks. Bow is done and I will work to the stern, alternating each side just in case I twist the keel. I think that shouldn't happen given the deck is in place but it is still humid over here and there is always that chance.Crying Unsure
Did you have any issue with glue line. I find it can be an effort to get an even finish between the softer balsa and the rigid glue. I use PVA what do you use.
Brex
Guest (8)
This page was generated in 0.258 seconds.
