 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,510 Points: 4,442 Location: Essex
How are people finding the rear wing. Someone mentioned it was a bit tricky so was wandering what everyone else thinks. I have not received pack 2 yet so don't know myself. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
 Rank: Pro  Groups: Registered
Joined: 01/07/2011 Posts: 383 Points: 1,194 Location: Birmingham
Personally I found it pretty simple. Much easier than the MP4-23. I did steal someones idea of using a right angle to get it all straight which helps.
how did you go about gluing it. not sure about using the ema liquid as you have to hold the pieces in place and let it run into the join and was just worried that the black paint on the end plate would desolve as seems to happen when using the ema. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
I used a cocktail stick to apply a little bit to both contact areas. On the end plate I joined the dots with a thin line and its holding so far.
was this using the ema liquid? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
I may be wrong and I'm sure someone will correct me if it but I used this!  Its held firm for me but as I say not 100% its right.
If it's done the job then who is to say it's wrong Ian Spencer
only1ianuk wrote:Personally I found it pretty simple. Much easier than the MP4-23. I did steal someones idea of using a right angle to get it all straight which helps. Anyone who has done the 4/23 rear wing will find this much easier! Spencer
ok, thanks. pack 2 will be arriving hopefully in a couple of weeks so will keep this in mind, cheers. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Joined: 25/09/2013 Posts: 112 Points: 308 Location: UK
Warthog wrote:only1ianuk wrote:Personally I found it pretty simple. Much easier than the MP4-23. I did steal someones idea of using a right angle to get it all straight which helps. Anyone who has done the 4/23 rear wing will find this much easier! Spencer I am just assembling my rear wing and I certainly agree!! I use this glue for most of my assemblies, it's not runny and the needle dispenser makes it very easy to apply in small amounts, avoiding the dreaded overrun:- http://gshypocement.com/
I've already suffered a glue attack on the nose cone, which required a replacement part, so I'm not taking any more chances!!
