 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,510 Points: 4,442 Location: Essex
I am a month behind most people as I ordered later but that gives me the benefit of learning from others as they go.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
Stage 1 is complete. I am leaving stage 2 until i get pack 2 as I will assemble the front wing after I have glued on the end plate skids. Stage 3 which is mainly the disc and caliper I have done but will post a pic after I have done the wing.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Joined: 01/09/2012 Posts: 111 Points: 306 Location: Nottinghamshire
Nice to see another build in progress.
Dave
Good start and congrat's on your first medal
Pack 2 has arrived now so am finally able to complete stage 2 by attaching the wing skids.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 2 now completed. With the addition of stage 6 skids.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 3 completed ages ago  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Now got this lot to contend with. Pack 2, stages 4-7.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Ah I bet your looking forward to it really  great start btw and look forward to seeing you progress. Spencer
It doesn't look too bad. Not to sure about the rear wing, looks a bit tricky Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
It's a lot less complicated than the MP4/23 rear wing and as long as you take your time and allow the adhesive to cure before trying to finish it in one go then you will have no problems Spencer
What would you recommend for the wing assembly. Abs plastic weld or poly cement? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Me personally, I would use and am using ABS plastic weld (MEK) but this question has been asked of me more than once and I'll keep giving the same answer Spencer
Started on stage 4 today  got clutch and engine rear done   Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 4 completed. Time to crack on with stage 5 now  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Done the marlboro decals on the rear wing before assembling . Not come out too bad but not happy with the top of the 'L', the top corner folded under a bit and couldn't retrieve it  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Tonight's progress  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Coming along nicely Steve Regards Spencer
Thanks Spencer. For anyone following some advise would be to glue the main wing to the end plate on its own and when that's dry glue on the lower flap after and then glue the little silver joint on afterwards. This way you can make sure the ends where they glue to the end plate will be level if that makes sense. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 5 is now complete. Rear wing not as difficult as I thought.    Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
