Very nice Andy, I love this build Steve
 Hi Steve Thanks for looking in and your comments regard Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Issue 11 comprises of the wing light wiring ,the second undercarriage leg , aileron hinges and side cockpit instruments/radio/battery box. The lighting wires were added 1st then the fuel tank to the wing section after that the undercarriage was added along with the gun, lastly the wheel well's were added to the wing. lastly the battery box/ side intsruments and radio were assembled where needed undercoated then painted up before fitting in position regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, looking good.. Regards Alan
Very nice Andy, coming on really well - This is such a good quality partwork, just wish I had space to display an aircraft,they just take up so much room. Steve
 Hi Alan Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Steve Certainly a quality kit and build , Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Lovely work Andy this part work looks stunning  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
 Hi Martyn Thank you for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All This month its a great deal of panels for the cockpit to paint and fix in position. The left wing also has the flap made up and fitted, the air intake fitted, the upper skins added and the folding wing tip fixed to the wing. The last thing to be made up was the first of the ailerons. More soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
The cockpit is looking really detailed now Andy, looks fantastic. Steve
Hi Andy, the more I see this build the more impressed I become.... stunning kit and great work..... Regards Alan
 Hi Steve Thanks for looking in and your comments. Your right about the cockpit starting to look busy now although all the parts are supplied in cast form and have to be painted so not looking too bad. Im just glad the seat will go in from below  as its getting a bit crowded in the upper parts. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Alan This is an outstanding kit and build goes together like a dream unfortunately it is now no longer available here. Thanks for looking in and your comments Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Another instalment on the build. The first thing to do was to make up the second aileron, this one will be covered in nylon and painted silver to reflect the silver dope used on fabric coverings of the period. Then next thing was to add the high tensile leads and spark plug leads to the engine and make up the engine mount. A very simple but clever and nifty jig was provided to start the build of the rear fuselage I will be painting this after all the former's and stringer's have been added. Finally the radio tray was made up and fitted as was the aileron tab adjustment wheel in the cockpit then the outer cover for the spent shells ejector unit was added. More soon Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, Some lovely work going on there. I`m gonna have a wealth of info when I start mine in the future. Thanks for some easy to follow pics and info. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Hi Del Thanks for looking in and your comments Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Coming along nicely Andy  Very nice indeed Spencer
 Hi Spencer Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Some more done on the Zero. The rear fuselage has been made up with all the stringers now in place and sprayed with Aotake and the fuel tank and oil tank sprayed with Aotake, the fuel tank has been fitted but not the oil tank as yet. The rear part of the engine has been painted and added to the engine mount and finally the deceleration chamber has been painted and added to the propelor assembly. More soon Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (18)
