 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,510 Points: 4,442 Location: Essex
Stage 6 now complete. As I had done the front wing skids earlier this was only the rear wing support. I have not glued it in yet as someone on here advised to wait until later on in the build but they are glued together.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
Coming together well Steve, nice work.
Started stage 7 now. This stage concentrates on the engine. Got the cam cover logos glued on then the cam covers loosely screwed on to the engine. Also glued on the air chamber end. I noticed after taking this pic that there was some'fogging'on top of the badging from the instant adhesive. I was able to remove this with a sharp knife. It only really showed up on the flash anyway  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Looking good Steve, a little late I think but using a toothpick to apply the instant adhesive as in the official build diary will make sure that you don't get any overspill.. It's always a rule of thumb that when using superglue to make sure you have clean grease free hands/fingers etc as any "sweat" from your fingers will then activate and draw the fumes from the glue and fog. Now, rather than use a blade to remove the fogging you can use some future floor polish lightly over the fogging and this will hide the fogging, it won't remove it but it saves damaging your parts. Spencer
Thanks, I'll give it a go. But to be fair it is not that bad really. The flash from the camera makes it look worse then it is. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
As long as your happy with it Steve, that's all that matters Spencer
When I came to gluing the air chamber end to the plenum I did do it by putting a bit of glue onto a plastic sheet and then using a tooth pick which I found much better. All part of the learning process I suppose. After all this is my first model! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Well your doing a good Job Steve and plenty more parts to glue in later stages to get your teeth into Spencer
 Rank: Pro  Groups: Registered
Joined: 08/11/2012 Posts: 195 Points: 600 Location: Melbourne
Looking good Steve.
I'm starting to think I should have done my Marlboro decals at the time of building rather than leaving them until a later date!
Dave
It's only the rear wing I'm putting the marlboro decals on early. Just thought the wing would be harder once assembled. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 7 now complete. The 2 alternator halves were glued together and test fitted to the engine with the belt and the 2 parts glued to the plenum. That's pack 2 finished now. Waiting for pack 3.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Pack 3 here now so time to get on it again. Not that this pack will take long!  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
You will be amazed at how quick a month goes by Spencer
Coming along nicely Steve, looking good..... Regards Alan
Stage 8 done.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 9 done now. The large parts which are the left radiator housing parts are not used at this stage so have not been opened.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
That's stage 10 and pack 3 finished now. Awaiting pack 4. At least that pack will have a bit more to do!  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Pack 4 here now, stages 11-14. Comes with a free cutting mat.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 11 done now. Same as stage 8 really  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
