Joined: 26/04/2010 Posts: 5 Points: -5 Location: nottm
Hi,As we are now attaching bottom deck to ribs with tacks do we glue the ribs to the hull now or at a later stage or should i have already glued the ribs to the hull, Thanks,Colin.
read this - http://forum.model-space....aspx?g=posts&t=814
also the magazine tells you not to glue yet.
Oh no! Was just going to start gluing mine as I have now secured the first 4 decking pieces. Should I be waiting then as I was following the magazine instructions but do appreciate these can sometimes be out of step. Hope you can advise. Kind regards AJB
ajbird74 wrote:Oh no! Was just going to start gluing mine as I have now secured the first 4 decking pieces. Should I be waiting then as I was following the magazine instructions but do appreciate these can sometimes be out of step. Hope you can advise. Kind regards AJB Once I had made sure everything was square and the 4 deck pieces were pinned, I turned the hull over, leaving the jig in place for the added weight to keep things square, then mixed up a 70/30 solution of PVA and brushed it in all the seams as per the magazine.  Only thing was it needs longer then a day to dry properly........more like two  .But once it was dry, the strenghth in the frame is suprising.  Also when i fitted the gundeck support beabs I used the solution again to fill the cuts whick allow the sopports to bend and also aroud the edge where the supports touch the deck. Its that strong now I reckon It could take a broadside from the real ship!!!!!
Joined: 20/03/2010 Posts: 498 Points: 1,522 Location: South Wales
Jack Sparrow wrote:ajbird74 wrote:Oh no! Was just going to start gluing mine as I have now secured the first 4 decking pieces. Should I be waiting then as I was following the magazine instructions but do appreciate these can sometimes be out of step. Hope you can advise. Kind regards AJB Once I had made sure everything was square and the 4 deck pieces were pinned, I turned the hull over, leaving the jig in place for the added weight to keep things square, then mixed up a 70/30 solution of PVA and brushed it in all the seams as per the magazine.  Only thing was it needs longer then a day to dry properly........more like two  .But once it was dry, the strenghth in the frame is suprising.  Also when i fitted the gundeck support beabs I used the solution again to fill the cuts whick allow the sopports to bend and also aroud the edge where the supports touch the deck. Its that strong now I reckon It could take a broadside from the real ship!!!!! I agree, it is stronger now lol, but I dont think mine could take a beating off the wife, so I'm still treading carefully. Besides, I though after the decks were in place we should glue the ribs with diluted PVA, or was I tripping on too much caffeine? lol Ship Builds on the go
Yamato - DeAgostini Subscription - Highly Recommend This Model AKAGI - DeAgostini Subscription - Highly Recommend This Model RMS Titanic Lifeboat (Kind Gift from DeAgostini Crew)
Lonestar Spirit wrote:Jack Sparrow wrote:ajbird74 wrote:Oh no! Was just going to start gluing mine as I have now secured the first 4 decking pieces. Should I be waiting then as I was following the magazine instructions but do appreciate these can sometimes be out of step. Hope you can advise. Kind regards AJB Once I had made sure everything was square and the 4 deck pieces were pinned, I turned the hull over, leaving the jig in place for the added weight to keep things square, then mixed up a 70/30 solution of PVA and brushed it in all the seams as per the magazine.  Only thing was it needs longer then a day to dry properly........more like two  .But once it was dry, the strenghth in the frame is suprising.  Also when i fitted the gundeck support beabs I used the solution again to fill the cuts whick allow the sopports to bend and also aroud the edge where the supports touch the deck. Its that strong now I reckon It could take a broadside from the real ship!!!!! I agree, it is stronger now lol, but I dont think mine could take a beating off the wife, so I'm still treading carefully. Besides, I though after the decks were in place we should glue the ribs with diluted PVA, or was I tripping on too much caffeine? lol Thats exactly the way, PVA after pinning the deck!!
