8 Pages <12345>»
The Black Pearl build Options
#41 Posted : 13 August 2014 10:47:16
Hi pinks666
Looking a very nice clean build.
It's coming along a treat.
Happy modelling
Tony
swordfish fairey
#42 Posted : 13 August 2014 13:41:04
Hi Pinks, looking good buddy but, I think you may have transposed the rear side walls (parts 78 & 81).......Part 81 that has the shallower tab cut out at the front goes on the port side to allow the next panel (part 83) to also fit onto the frame..........Part 78 has a deeper cut out and this goes on the starboard side flush with the frame for the cutaway section......
Working on the theory that a picture is worth a thousand words....
This is the port side with the two walls sharing the frame....
This is the starboard side with the wall flush with the forward edge of the frame.............
Tony
Pinks666
#43 Posted : 13 August 2014 21:28:39
Hi Tony,
yes, you are exactly right, I noticed this last night when all of the glue had dried.
I now have the fun of carefully prising off the panels and restarting. a little bit frustrating but...to look on the bright sided, at least I get to drag these issues out a little longerLOL Cursing LOL.
I will be carrying out the repair over the next few nights and then post the refreshed pics.
It is all a learning curve and at least I have re-learned a valuable lesson...MEASURE TWICE, CUT/GLUE ONCE!!!
thanks for the update though Tony, glad to know you are all looking out for the beginners.
Marc Heeley
#44 Posted : 13 August 2014 21:41:03
Hi Pink,
It's not a big deal, everything can be fixed - if you used pva on plywood then water on the joint can soften it for removal but, as the frames are mdf then you need to be very careful you don't soak them as they can expand and distort. Good luck with it anyway
swordfish fairey
#45 Posted : 14 August 2014 18:32:47
I would be tempted to leave the one you have glued in place and just modify the other side piece, it may save you a lot of hassle..........Tony
riff-raff
#46 Posted : 18 August 2014 18:14:49
You could always add a piece to the frame to allow a gluing surface for the next piece
Built:
Pinks666
#47 Posted : 23 August 2014 17:59:34
Hi all,
I was considering carrying out one of the alternative repairs but I eventually decided to try to strip back and re-build properly. I must say, I am glad that I did.
As you can see from the pictures, the only issue that I had to overcome was that I split one of the gun ports in half, but with a little glue and a couple of heavy duty clamps....all was as good as new.
Next up was re-assembly. With one thing in mind(once bitten, twice shy) I used a bit of common sense this time and laid the pieces out BEFORE using any glue, and putting the whole thing togeyher the right way round this time.
Pinks666 attached the following image(s):
Marc Heeley
Pinks666
#48 Posted : 23 August 2014 18:08:52
Continuing with the rest of the panelling up, I have come across another problem....it is very easy to damage and split the gun ports whilst trying to remove them from the frames. this is due to the size and thickness of the pieces. So, rather than try to use a craft knife to cut them out, simply use the drill at the connection and just drop out free of fuss as pictured.
May seem obvious but already licking up alot of little tricks to ensure this goes as well as possible.
Marc Heeley
#49 Posted : 23 August 2014 18:16:59
BigGrin Hi Pinks
A very good resolution to your problem and well done, i bet that you feel its a job well done now. Keep up the good work
Pinks666
#50 Posted : 23 August 2014 18:20:16
hi Andy,
It was only a small set back but I am chuffed to bits with sorting it out rather than ignoring it. I may have got away with it as I don't think you can see any of these boards once the build is completed but I feel better knowing that it is the best that I can do
BigGrin BigGrin BigGrin BigGrin BigGrin LOL LOL LOL LOL BigGrin BigGrin BigGrin BigGrin
Marc Heeley
swordfish fairey
#51 Posted : 23 August 2014 19:11:04
Great work getting round that Pinks, your 'Pearl' is looking good........
I use an Exacto razor saw to cut out the bits and it works fine as you only need to use the tip of the saw blade to sever the pips that hold the bits together...........Keep up the good work buddy...........Tony
#52 Posted : 23 August 2014 19:11:34
Pinks
Very professionally done - well done.
There is nothing more niggling than knowing you have something wrong buts it oh so easy to try and ignore.
To pull apart what you have already done takes some real dedication and skill.
Very well done.
Happy modelling
Tony
#53 Posted : 24 August 2014 00:34:55
She really is looking good Pinks, keep the pics coming, am loving your build....Cool Cool
Pinks666
#54 Posted : 24 August 2014 20:03:41
Thanks all for the great response to my pictures,
I have got a little further so I will be posting more throughout the week.
BigGrin Happy Modelling.BigGrin
Marc Heeley
Pinks666
#55 Posted : 24 August 2014 20:04:14
Marc Heeley
#56 Posted : 24 August 2014 21:15:19
Pinks666
#57 Posted : 24 August 2014 22:17:18
Hi Steve,
Thanks very much, I have been following your victory build as I have this building up. I have not started yet but taking notes, and hoping it goes as well.
I will be starting in the next couple of months so due to get very busyLaugh
Marc Heeley
#58 Posted : 28 August 2014 16:44:08
She's looking good Cool
#59 Posted : 28 August 2014 23:32:15
Well done Pinks, coming together very nicely...... Cool Cool
Pinks666
#60 Posted : 31 August 2014 18:10:59
Things are going a little slower than expected.
though the wood dye that I am using is giving a great colour to the wood, it has taken me 7, 2 and 3 coats respectively as pictured below, so as you can see, alot more is required.
Still, definitely worth taking my time over.
Happy modelling all.
Marc Heeley
8 Pages <12345>»
This page was generated in 1.104 seconds.
