162 Pages «<140141142143144>»
#2821 Posted : 28 September 2014 22:13:15
BigGrin Very nice work Alan she is certainly starting to shine with all that gingerbread on showCool
Thanks Andy, appreciated as always... and to think there is still a lot of bling to add yet... She's also getting weighty now.... Cool Cool .. Thanks again
#2822 Posted : 30 September 2014 22:41:22
Issue 108 now complete with the construction of 24 gun port lids, 8 painted with a black facing and the other 16 left as natural sapele... Quite straight forward in constructing these but would give one word of caution.. the sapele overhangs 3 sides of the lids and these overhangs are very brittle, I broke the overhang off on two lids so had to re-do.... No hinges provided as yet, I think these are supplied with the next issue.... Cool Cool .. Happy building all
#2823 Posted : 01 October 2014 13:01:04
Looking really great Alan..I only wish that my build was as advanced..Your doing a fantastic job mate..love it!!
Drool ThumpUp
#2824 Posted : 01 October 2014 14:38:16
That is some seriously small parts you have been working on there so well done on getting them complete.
Guess your getting near to the stage nowvof having to mind you don't accidentally knock "sticking out bits" off.
Lovely build around.
#2825 Posted : 01 October 2014 15:01:51
#2826 Posted : 01 October 2014 22:59:08
Drool ThumpUp
Hi Jonny, always appreciate you looking in and commenting... Am pleased you like it... thanks again....
#2827 Posted : 01 October 2014 23:01:36
Thanks for the kind comments Tony.... Yes, having to be a little careful now as more and more small fiddly parts are fitted.... Still a lot more to be added yet but getting closer now to start working on the masts.....Cool Cool .. Thanks again...
#2828 Posted : 01 October 2014 23:02:45
stevie_o wrote:
some fiddly work there Alan, coming along very nicely thoughBigGrin
Thanks Stevie, lots of fiddly work now but am thoroughly enjoying it.... plays havoc with the eyeballs though....BigGrin BigGrin
#2829 Posted : 02 October 2014 16:22:36
BigGrin Lovely work on the paint work and the gun port lids ThumpUp Rgd Martyn
captain bligh
#2830 Posted : 02 October 2014 20:37:43
Looking Good Alan!
Keep up the good workThumpUp
David.
Promise too much ...and many will be in search of you!
captain bligh
#2831 Posted : 02 October 2014 20:43:38
Hi AlanBigGrin
I take it the first cannon does not have the eyelets attached? There are eyelets with the kit of issue 1.. are these for the second cannon (larger type?)
David
captain bligh
#2832 Posted : 02 October 2014 22:39:32
This is lovely work Alan!Drool
just hope mine's as good as yoursUnsure
David.
captain bligh
#2833 Posted : 02 October 2014 22:49:03
Hi Alan
Cracking work on the gunportsDrool
whats the tool you are using for this if you don't mind me asking?
David
#2834 Posted : 02 October 2014 22:57:28
Thanks Martyn, appreciate you looking in..Cool Cool
#2835 Posted : 02 October 2014 23:12:19
Thank you for you kind comments Dave and am sure your build will look great, just take your time and study the work to be done carefully.... I'll answer all your questions to your posts in this one reply..
Firstly the cannons, all the cannons will have eyelets fitted even the first cannon you make up... The eyelets in issue 1 will be used late. In fact I should point out here that not all items supplied in each issue will be used during the work to be done on that issue. Any parts you do not use will be used later so what you have left you should place in a plastic bag, marked with the issue number and carefully stored until required. Cool Cool
On the gun ports, not quite sure whether you are referring to the cutting out of the gunports or the making of the gunport lids... Gunports were cut out using a dremel with a carving bit. If you look at page 1 of my diary you will see an index which will take you to the part of the build on cutting out the gunports... Tools used for the lids were simply a modellers knife and a very fine sanding block....Cool Cool
Hope this answers your questions and thanks again for looking in and commenting...
#2836 Posted : 03 October 2014 14:01:42
Excellent job there Alan. well done. She is really coming together now.
#2837 Posted : 03 October 2014 22:53:03
Thanks Hans, always appreciate you looking in and commenting....Cool Cool .. Thanks again...
#2838 Posted : 03 October 2014 23:03:46
Tonight I finally finished one of the anchors. My first attempt at an anchor many moons ago was not my best but used it as a learning exercise... Thought also the stock was a little too short so on this one I increased its overall length by 5mm.. Stock has been given 3 coats of medium oak stain followed by a coat of satin varnish... I also decided to discard the supplied ring and fitted a larger one. Added puddening to the ring using the brown rigging thread supplied. Finally drilled .5mm holes and inserted some cut planking pins.....
Moved onto making up the figurehead. First problem was to deal with was to move the front hole to accommodate the pin on the horses hoof, the hole was about 2mm out... First filled the hole, sanded it all down and repainted... Drilled the front hole in its new postion. Glued the horse and figures in place as per the mag instructions... Small little touch ups needed to finish it off but for now thought I would sit it on the bow of the ship to see how it would look.... It is not glued in position as yet....Cool Cool ... Happy building all..
captain bligh
#2839 Posted : 03 October 2014 23:48:06
Well tonight the POTS finally got the scalping it deserved so can now once again be classed as the SOTS.... LOL LOL LOL .. Obviously still more treenailing on the upper hull to be done but can't do that until after I have dry fitted the gallery and planked the area around it.. Cool Cool .. Tomorrow will get down to the business of gently sanding it down to hopefully give it the subtle look I am after.... Cool Cool .. Once that's done will move onto tidying up the stern area in preparation of starting the second planking layer of the lower hull..all to be done in walnut.....BigGrin BigGrin ...
Hi Alan
This is your first build of the SOTS?.... what can i say.. look at all that dedication!!!ThumpUp ThumpUp ThumpUp ThumpUp
captain bligh
#2840 Posted : 03 October 2014 23:54:32
Cheers Alan!BigGrin BigGrin
Guest (145)
This page was generated in 0.213 seconds.
