lower front wishbones pick up points Options
Steve279021
#1 Posted : 04 October 2014 18:30:01
At the bottom of the monocoque there seems to be what appears to be the lower wishbone pick up points inside it where the wishbones go into the chassis but there only seems to be them on the front 2 positions but only 1 of the rear ones have a pick up point hole, there doesn't seem to be one for the right hand side of the chassis.Is this correct? Just want to check before I attach too much to it.
Dodge charger build complete
Senna lotus 97t complete
Warthog
#2 Posted : 04 October 2014 19:40:00
Hi Steve
All will be revealed in future issues so try not to look into what you may see as a problem that isn't actually there..
And to answer your question... It is correct.
Spencer
Steve279021
#3 Posted : 04 October 2014 21:15:38
Thanks Spencer. Just wanted to make sure it was ok. It just looked a bit odd that was all. At least I know the chassis is correct now
This page was generated in 0.043 seconds.
