Spitfire build problems Options
f1marshal
#1 Posted : 17 January 2015 13:49:46
Hi everyone
I know ive been a bit quiet on here but had no laptop for a while.
I decided to have a go at the spitfire and just received my 1st pack and the frames do not fit the sides of the fuselage not sure if they are the right parts or not. Seems like they are from different kits.
Cursing Cursing Cursing Cursing
Paul
Current builds:
1/24 Spitfire
1/48 Apache Longbow
Titanic Lifeboat
#2 Posted : 17 January 2015 14:08:31
Sorry to hear that.
Can you post a pic of what you have received or possibly compare what you have with the parts pic in the official build to identify any differences?
f1marshal
#3 Posted : 17 January 2015 14:59:57
I will try not put any pics on for a while
Paul
Current builds:
1/24 Spitfire
1/48 Apache Longbow
Titanic Lifeboat
#4 Posted : 17 January 2015 15:11:49
Hi Paul, if you can't remember how to post pics then hopefully this will help you out....Cool Cool
http://forum.model-space....aspx?g=posts&t=244
f1marshal
#5 Posted : 17 January 2015 15:19:07
hope this works
Paul
Current builds:
1/24 Spitfire
1/48 Apache Longbow
Titanic Lifeboat
Warthog
#6 Posted : 17 January 2015 17:14:38
Hi Paul
Can you provide a full picture of both parts please and also if possible some measurements of the edges where they are supposed to fit together so I can then confirm which part is incorrect. To me it looks like the side fuselage half but need to confirm.
Spencer
#7 Posted : 17 January 2015 17:21:48
hi Paul,
There are only two sections this shape so it must be section two(cockpit bulkhead)just wondering if you have tried that end.
Regards Trev.
f1marshal
#8 Posted : 18 January 2015 11:46:08
Hi
I just measured the end tab on the fuselage side and its 40mm on one and 44mm on the other one,also the next tab along is also different sizes 40mm and 43mm so noe of the frames fit on both sides.
Paul
Current builds:
1/24 Spitfire
1/48 Apache Longbow
Titanic Lifeboat
Warthog
#9 Posted : 18 January 2015 12:11:52
Hi Paul
You will need to request a replacement fuselage side as the part you have already started to assemble is incorrect.
It's not a problem we've come across before either.
Contact details here:
0845 1489 250/251 or email customercare@deagostini.co.uk
Spencer
f1marshal
#10 Posted : 18 January 2015 13:03:26
Thanks Spencer
I was thinking the same thing but just wanted to clarify it first.
Paul
Current builds:
1/24 Spitfire
1/48 Apache Longbow
Titanic Lifeboat
#11 Posted : 18 January 2015 13:51:31
It does indeed look like you have a rogue part Crying
#12 Posted : 18 January 2015 14:44:59
Hi Paul, Confused
Sorry to see you have a parts issues with your Spitfire.
Just measured my fuselage at the point shown in your pic below and the lug on the fuselage side measures 40 mm.
As Trev said earlier there are only two formers of this shape and having measured them both the front one is the smaller.
If you measure the front former and the fuselage side where indicated in the pic above it should tell you which part is at fault.
Hope this helps define your issue, so you can get it corrected asap.
DaDokta
#13 Posted : 19 January 2015 08:40:30
In germany and austria we had multiple shipments with wrong fuselage side parts.
You will need to call for a replacement!
DaDokta
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
