were There any problem issues? Options
Steve279021
#1 Posted : 21 January 2015 09:33:33
As you may or may not know I have acquired a complete MP4/23 kit. I was just wandering during the run if there were any problem issues like wrong parts or parts missing or wrong mags etc? All the parts have not been opened and I am not sure when I'll start the build so I don't want to open the packs for no reason but i will check problem ones.
Dodge charger build complete
Senna lotus 97t complete
#2 Posted : 21 January 2015 09:49:34
Steve279021
#3 Posted : 21 January 2015 12:03:34
Yeah I Read about them ones. Will check them tonight. Are they the only ones work checking?
#4 Posted : 21 January 2015 12:31:31
May also be worth checking issues #70 and #71? Each contains one half of the induction pod along with its' relevant induction pod support and induction pod fin. My issue #71 had a left side fin which is normally in issue #70, instead of a right side fin and they aren't interchangeable? You can see them here:
http://forum.model-space...aspx?g=posts&t=4583
I don't recall anyone else mentioning this, probably just a rogue part and I was unlucky (mistakes can happen), but the part was replaced very quickly and efficiently by customer services who are normally very good?
Steve279021
#5 Posted : 21 January 2015 12:37:45
i will check that too thanks. customer services wont be able to replace any wrong parts as i didn't buy it off deagostini. i bought the lot off ebay but i'm assuming i'd be able to buy back issues if there was a problem.
Steve279021
#6 Posted : 21 January 2015 19:29:55
Well I Have checked 70, 71, 73 and 74 and they are all ok. Has anyone else had any problems with any other issues?
This page was generated in 0.051 seconds.
