dandare wrote:RM1 wrote:Some very nice work there Dan! Some great additions to what looks like an excellent kit. I'll follow this diary closely. Could you tell me please what you use to clear coat the decals? many thanks Malc. Hi Malc ive had great success with Zero paints 2 pack gloss, it goes on very well dries great and polishes to a fantastic finish (I will never use any other Gloss now), no reaction with Acrylic or Lacquer based paints. BUT this must be used with a mask as it contains isocyanates! Regards Dan Hi Dan, Many thanks for the information I'll see if zero paints are available here in SA. malc.
Joined: 10/02/2014 Posts: 63 Points: 189 Location: uk
Hi Casino yes the decals (assuming they are the same) are very dark grey/black & "clear" the clear part of the decal clearly shows through the colour of the rear wing end plate. to emphasise the difference i used a mix of Tamiya Aluminium & gun metal (mainly aluminium) on the inside of the end plate and although ive not done it yet i will tone it down further with a "hint" of "alclad" transparent smoke before doing a clear coat of alclad light sheen.
regards Dan [/quote]
Hi Dan
ok the paint must be the difference then as yes they are the same decals, i was a little miffed to say the least when i applied one and let it dry only to find i could not see the difference.
thank you for the info
C
Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
caught up with the right hand side pod with regard to the silicone pipes and jubilee clips, i also decided to cut of the inter cooler access panel cover "dimples" and changed them for some bolts. also finished off the rear wing but its in need of a clean up after polishing. nearly forgot, managed to make the radiator clips as well regards Dan dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
It's coming along nicely Dan and your doing a great Job Spencer
Warthog wrote:It's coming along nicely Dan and your doing a great Job Spencer Thank you Spencer its difficult, as i keep seeing little bits i want to do, but its such a great model already, so just a few little bits (and a few mistakes, new callipers needed lol) will be packing it all away for a good few weeks as house move will be in progress soon. regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
hi all, unfortunately this will be my last post on this build for a good few weeks as all the gear is to be packed away and shipped to a new address very soon. anyway ive been working on the mono in the last couple of weeks! to get the rough stipple effect on the front nose area i brushed on tamiya flat black and continued to work the brush until the paint dried, i then used alclad pale gold for the front base coat and alclad aluminium on the rear before applying the carbon decals. after a few days i dusted over the decals with a coat of alclad gunmetal to tone it down. dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
sorry for all the blurry photo's (they looked good on the camera screen) i gave the seat base/cockpit internal a coat of halfords matt black & although the picture came out bad i did actually apply carbon decals to the gear knob area! dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
some more photos dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
I then applied the sponsor decals & left alone for a couple of days to fully dry out. a coat of Alclad Flat Clear to the outside of the monocoque came next. the internal carbon around the gear knob will be given a coat of clear gloss. As i have 2 sponsorship decals for the nose i don't have to wait until the main body arrives to fit into place (part of the decal sits on the main body)so added one to the nose and the other will be used for the part that sits on the body section  so now i can clear coat the nose and finish that off. Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
can anyone help? all my photo's have disappeared?? or is it just me that can't see them?? regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Scrub that just read about the problems from the downtime regards dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Hi All nearly back to making some models! still some unpacking to do but found that whilst i was doing some of my said unpacking i was kinda doing bits and bobs (was unpacking and organising model materials etc)that said i somehow drilled the inter-coolers and radiators, inserted some connectors and fitted some pipework!!! crazy thing this modelling, it somehow distracts you from what your supposed to be doing i just need to work out how to get the radiator expansion pipes to look as though they have pink coolant within them!! Regards Dan dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
and a couple more photos of the mono, as the last where all blurry Regards Dan dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
 Hi Dan Looking great and i know exactly what you mean about being side tracked at times as for looking for a colour for the pipes try this one ,link below http://www.ebay.com/itm/...AINT-18ml-/310561609866
Im sure there are a few more out there but hopefully this may give you an example Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Good Call Andy looks good, so i think i will have to give it a try regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
not much to show at the moment! been working on the carbon for the brake cooling ducts and turbo inlets, but these are not ready yet so you will have to wait till another update. only managed to fit some pipework on the RH air inlet and also, not that the photos show them but added some rivets to the cockpit gear knob panel. A couple of shots of progress so far and also alongside the MP4/23. Regards Dan dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,510 Points: 4,442 Location: Essex
That's looking really good Dan. 1 question though, how come you have all 4 wheels and tyres? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
Steve279021 wrote:That's looking really good Dan. 1 question though, how come you have all 4 wheels and tyres? Hi Steve, thanks for looking in. After messing up the brake discs  i needed some new ones, therefore fleebay came to the rescue with the added bonus of some other parts within the pack, i can now test out the worn tyre look Regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Ah, I see! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
