hull planking Options
johny5
#1 Posted : 08 September 2010 13:06:55
any one no wher i can get some spare woodstrips for the hull if broken most of mine
#2 Posted : 08 September 2010 13:09:33
2x5mm strips..BigGrin BigGrin
cornwall models lime strip
johny5
#3 Posted : 08 September 2010 13:25:34
thanks are thay the same ans the magazenBigGrin
#4 Posted : 08 September 2010 14:05:57
Sorry I'm not sure as I am still waiting for my issues too turn up, But looking at Tomicks build they are definitely 5mm wide as the gunports are 12mm and he cuts away 2 and a bit planks to get it.
Hope that helps.
Boaz
#5 Posted : 08 September 2010 14:12:48
Hi magppie
As I am almost defo going to double plank & paint is lime strip the best so as not to show to much grain?
Also should I buy & fit the lime strip first, then lay over the Deag strip, or does it matter? Confused
Thanks
Bob
#6 Posted : 08 September 2010 14:46:07
Hi Bob,
Limewood is softwood which doesn't show much grain if sanded with fine grade paper. As for Double planking, you can plank over the Limewood with no problems but you would be better with 1.5mm Planks and the veneer being 1mm thick. The Deag strips are Basswood which is the same as Limewood.
Hope that helps you .
Cheers Chris...
riff-raff
#7 Posted : 08 September 2010 15:31:23
http://www.cornwallmodelboats.co.uk
Built:
Boaz
#8 Posted : 08 September 2010 16:22:48
magpie1832 wrote:
Hi Bob,
Cheers Chris...
Thats great mate. But sorry for the noob question..
You say I would need 1.5mm thick planks?
What do you meen by veneer being 1mm?Blushing
#9 Posted : 08 September 2010 18:37:04
Hi Bob
What I'm meaning is , If you are double planking you would need to forget the deag planks and replace with 1.5mm planks otherwise the ship will be 1mm wider everywhere.
What I mean by veneer, the top layer of plank it being walnut or mahogany etc. It is better to be 1mm thick. any thinner would mean very little sanding...
Hope that gives you the info..
Thanks Chris...
Boaz
#10 Posted : 09 September 2010 02:10:00
magpie1832 wrote:
Hi Bob
Thanks Chris...
Ah got ya.Woot
Nice one.
Thanks Chris
Quintin
#11 Posted : 09 September 2010 08:03:55
be very with the veneer sanding, I got a little heavy handed with my HMS Endeavour, and went down to the planks. Huge bummer, I ended up having to replace some, and the hull is now a bit patchy in places. I tell myself it is a replica of the repairs done fy the crew when she ran aground on the barrier reef...LOL
Part time modeller, full time biker
Built: Pinta
Belle Poule (plastic)
Endeavour
Scratch build of Pirate ship "Neptune" (Based on cutter "HMS Aldebaran"
Current builds: Victory
Quintin
#12 Posted : 09 September 2010 08:05:23
erm, be very CAREFUL with the veneer. BY the crew... (me needs to learn the art of previewing posts...)
Built: Pinta
Endeavour
Quintin
#13 Posted : 09 September 2010 08:08:09
Hi, most hobby shops will stock the appropriate spares. Otherwise, here is an online shop I found, looking for parts for a soon to happen scratch build, it may help.
http://www.naturecoast.com/hobby/catalog.htm
Built: Pinta
Endeavour
Boaz
#14 Posted : 09 September 2010 18:04:38
Just another thing i have just thought. Do I need a veneer if I am going to paintConfused
The main reason I am going to double plank is that I am no way confident with my first attempt at planking as this is my first time. And this is to expensive to cock up.Crying
Bob
Zeptrader
#15 Posted : 09 September 2010 18:13:29
Im sure you can Bob, but maybe some sanding sealant as mentioned before, see what others reckon.
Boaz
#16 Posted : 09 September 2010 18:26:31
Thanks for the vote of confidence ColinThumpUp
As you can imagine this is one great wop off learning curve.
For something that is probably going to end up costing close to a grand eventualy (as has been mentioned before in other posts) I want to get it spot on.
I'd prefer it to look "pre" Trafalgar rather than "post" if you know what I mean.
Bob
#17 Posted : 09 September 2010 18:48:20
All you have too remember is take it slow do one plank at a time and check and double check the fit of it first. Then you will have no problems. I had never planked a ship before when I made the San francisco 2 and that one is single planked. My HMS Fly is double planked which will also be my first Double planked.
You can do it if you take it easy Bob.BigGrin BigGrin
alantait
#18 Posted : 09 September 2010 19:03:50
all my models have been double planked so far, like you i will be double planking the victory as no matter how many ive done (Five) some bits still dont look right with the mistakes i made, so a second planking helps hide these and its neater, i wouldnt think a millimeter or so would make a great difference overall.Confused
current builds
