 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,510 Points: 4,442 Location: Essex
I thought whilst waiting for the next pack and now that I've got all 4 wheels and tyres then I'd take the opportunity to 'rough' up the tyres. I used 1500 grit and wish I'd used 800 as was advised as it took ages. But I'm happy with the result. Before  After  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
 Nice result, I will be doing the same with mine Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Great result on them tyres. Would be great if it could have the rubber bobbles on them too. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Tyres look really good,how did you get such a good finish and also such an accurate line around the the edge of the tyre?
The finish was achieved by using a finer grade of paper but it took longer to do. I used 1500 grit. It's not hard to get the line at the edge as long as you keep the paper flat across the tyre when rubbing and not go round the edge onto the side wall and I always rubbed in a linear motion and not across the tyre face. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Excellent result on those tyres.!
Pack 15 here now. Getting moving with the engine now.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Excellent work so far Steve, this is turning into one to watch.Very nice build, all very neat and tidy and those tyres look fabulous, they will certainly add a nice touch of realism to the finished model - very well done!!
I think you made the right choice to use the finer grade abrasive even though it took longer? If you had used the more coarse grade it could possibly have torn the surface of the vinyl tyres and ended looking a little rough, but yours looks spot on - nice job sir!!
Kev
Thank you very much kev Glad you like it Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
That's a hell of a difference with the tyres, they look so life like now, awesome job
 Nicely done Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice finish to the tyres! Greetings, Walter
Thanks for the comments. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Engine underway. Cam cover bases and intake manifold bases fitted.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Front, back and sides on the engine now.  Got a bit of an issue with fitting 1 of the plugs top the right cam cover. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 50 finished. Cam covers and plugs fitted.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Engine lower sides fitted.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
 Looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Stage 51 done. Intake manifolds, connector on left radiator housing and gearbox hose fitted.    Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 52 started. Water pumps, oil pump and engine bottom.   Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
