Very nice Andy, I love the detail in these F1 cars. Somehow I missed you starting this
 Hi Dave Thanks for looking in and your comments, the senna car is a must as it was just outstanding engenearing for its time in the hands of a master. I would reccomend it to all. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Pack 16, firstly the pop-off valve was made up and then added to the ducting and then mounted on the plenum chamber along with the throttle link. Next the oil/water heat exchanger was made up and the 8 tapes cut and added to the four brake lines to represent the cable ties on each of the suspension arms. Now the front brake ducts and throttle bracket were added along with the two radiator pods to the monocoque. lastly the injectors were added to the engine and the fuel pipes made up. More soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,495 Points: 4,397 Location: Essex
You got your front brake ducts the wrong way round Andy! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
 Easily sorted as I  didnt glue them in place and thanks Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Coming along nicely Andy Spence
Apart from that, looking good  . Nice to the see the big parts coming together now. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
 Thanks Spence and Steve for looking in and your comments much appreciated Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
This is a very nice looking model with a lot of fantastic looking detail Might have to add one of these to my want list
 Hi Dave Your right about the Detail on this model its very high and was one of the reasons I went for it. Its another kit that people will regret not getting hold of when the opportunity was there as with all partworks once its gone its gone. Thanks for looking in and your comments. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Pack 17 has arrived. Firstly the left hand turbo was assembled then the fuel hoses were added to the fuel rail this completed rail was then added to the engine block, this can be a tricky operation as the rail has to go under the fuel injectors fitted previously, so take your time and tweezers help a lot. Also I found it best to glue and hold each fuel line in place until the glue sets as they try to twist off because of the angle. Next the right hand turbo was made up then the fuel pump was added to the engine block and then fixed to the fuel rail, finally for this part the header tank hose was added to the bottom of the engine. The last few parts to be made up were the two wastegates ,then the oil/water heat exchanger was added to the the engine block. Next the valve and inlet pipe were added to the header tank then the two sensors were added to the plenum chamber, finally the two oil filter joints were added to the lower engine block. That finishes pack 17 more soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
super job Andy not long till the end regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
 Hi All Pack 18, Started off by adding the header tank to the engine along with the fitting of the plenum chamber next up was to add the nose box and lastly the engine was attached to the monocoque. Note the plenum chamber has not been glued to the intercooler pipes yet. Next I made up the left and right exhaust assemblys and added them to the engine then the turbo charger intakes/wastegates were assembled and dry fitted to the main assembly. The four hoses were next to be made up and fitted to the turbo's. I chose not to remove the motor to fit the hoses as they can be fitted with the engine in place also I have started to put a bend in the ends of the wires that go inside the hoses as this stops them popping through the hose. Lastly I have left the floor underbodys in place as it will protect those delicate exhaust assemblys. The ruler in the last pic is 150 mm long so gives a good idea of the size of this beast. More soon Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Last but one pack of this classic car kit. Made up the seat belt harness and then fitted the fuel filler valve, the gear linkage was also added here. Next I added the labels to the steering wheel, made up the telemetry wire and added it to the engine then made up the electrical components adding the wires as stipulated. Lastly made up the instrument panel and added the stickers also the brake balance adjuster was added. More soon. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nearing the end Andy and a fab result it's going to be.... looking superb... Regards Alan
Looks fantastic. You're doing a great job there Andy. I hadn't realised there was such cool detail in this model. The temptation to start my build is growing. Malc.
 HI Alan Thanks for looking in and your comments, yes nearly finished but what a great kit. There will be quite a few I think who will regret not subscribing to this like the Zero. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Malc Thanks for your comments and looking in. Your right the detail on this kit is high but still leaves scope for some upgrades too. My advice would be to start it when your ready, the wait may be a pain but the rewards will be worth it. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Well here she is finished, this is a kit I have enjoyed building a lot. Highly detailed and at times a chalenge it builds into a very large car the ruler you can see in some of the pictures is 6 inches long to give you an idea on its size. Whats next I will carry on with the Huracan and maybe start on my MFH kit but that will be a long build due to the prepping of parts. Regards Andy PS Now added the missing decal at the front. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
