stage 56 pack 16 Options
Steve279021
#1 Posted : 10 August 2015 18:49:00
Just a couple of questions for those who have done it. Firstly when gluing the radiator housings to the monocoque why is only glue used on a small section and secondly it says to fit the front under body then remove it a couple of times. Are we just holding it on or is it to be properly screwed on?
Dodge charger build complete
Senna lotus 97t complete
#2 Posted : 10 August 2015 21:19:59
Hi Steve
As far as I can remember the two strips on the side of the radiator housing's slot into the monocoque's recesses on each side this holds both the housings in place and although a small gluing area its all fine. It is also supported by the floor when its in place so just store it placed on top of it until final fixing. As for the underbody I think its removal has something to do with when the engine,gearbox and mono are finally joined together as one piece.
Steve279021
#3 Posted : 10 August 2015 22:05:25
That makes sense. Cheers andy
This page was generated in 0.079 seconds.
