Instructions Error in Stage 55 (Pack 16 page 437) Options
Captain Plummet
#1 Posted : 02 September 2015 16:23:29
I am currently working on Stage 60 (Pack 17), and I've just come to test fit the oil/water heat exchanger to the engine block.
However, I find that the joints on mine do not line up correctly at all. I assumed that I'd assembled the thing incorrectly, but I couldn't work out how I'd made the error, so I went back to the Pack 16 instructions and looked again at the assembly guide.
Bottom left of page 437 are two photos of what the assembled unit should look like, and I assembled mine exactly according to these photos.
However, both these photos show the upper joint mounted at 90° to it's correct orientation. In fact, the angle of the joint should be pointing away from the camera in the circular close-up photo, but it is clearly shown as pointing to the left.
Having assembled these parts according to these photos, I now find that there is no way I can get the upper joint to meet the engine block as it is supposed to. I'm currently trying to disassemble these parts, but as luck would have it the union between them is particularly robust, with relatively huge tabs on the inside of the join...
I think that this is a serious enough error to warrant some sort of free replacement parts for those of us who have already completed Stage 55 according to these photos.
Yes, I accept that the photo at bottom right of the same page, and those on the following page, show the part correctly orientated, but I put mine together using the photos at bottom left of page 437; that is how I had the assembly in my head from the test fit, which was surely the purpose of the test fit after all.
Edit: I have now managed to detach the incorrectly aligned part, but it looks ever so messy...
Steve279021
#2 Posted : 02 September 2015 16:50:46
I noticed that when I built that. I can't remember which way I done it though. I think I'll check it against the engine later to see if it's OK.
Dodge charger build complete
Senna lotus 97t complete
JD4EVER
#3 Posted : 02 September 2015 20:36:05
I know exactly what you mean as the photos are confusing.
I put mine together without glue a couple of times before I figured out the correct orientation and I also checked Warthogs build to be doubly sure.
Looking at the photos again you have to look at the page upside down to have the part built the correct way!
Steve279021
#4 Posted : 02 September 2015 21:04:56
Just checked mine and luckily I've done it right!
NSXKid
#5 Posted : 02 September 2015 21:17:13
I also noticed the error when I was doing this step. I looked at the official build diary video to verify the correct orientation.
only1ianuk
#6 Posted : 02 September 2015 22:12:39
I made the same mistake. Luckily I managed to prize it apart and then re-glue it the correct way
Warthog
#7 Posted : 03 September 2015 09:34:26
Gents
Thank you for bringing this to my attention and a note and adjustment of text regarding the image to that part of the assembly has been added in the official build.
It is always best to refer to either the official build diary or the official YouTube build as some of you have done before glueing any parts without any problems.
Spencer
ian2014
#8 Posted : 07 September 2015 21:38:04
Made the same mistake but come apart ok. Check twice glue once ?
Facebook-model maker
HarryAsh
#9 Posted : 10 September 2015 22:20:33
Rank: Beginner Level 1
As stated the photo at the bottom left of page 437 is incorrect but refers to a dry test assembly. Later on the right of page 437 and on page 438 when it comes to glue they are of correct orientation proving that the instructions must be followed to the letter.
This page was generated in 0.057 seconds.
