Joined: 05/12/2011 Posts: 133 Points: 270 Location: wick scotland
Hi just like to let you know il be starting a diary soon on this monster of a tank i did start this colection few years ago got to issue 30 then ran out of fund then had no use and binned it bad mistake so spent few months searching ebay and got lucky and got most the colection for 200£ witch i thought was a bargin only have issue 1-123 so will have to hope i can get the last few issues some were will probly go down the leave the model open route instead of screwing it all down and never seing the inside again building the spitfire,RMS Titanic hachette and now starting the u-96 submarine
Sweet another build the this monster, I couldnt believe the amount of plastic and metal in the box when I got mine. Fingers crosses you find the last issues and loo forward to seeing your build
Hachettepartworks.com has quite a few of the later parts showing in stock. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
She is indeed a huge build and I look forward to following your progress.... good luck with the build.... Regards Alan
Joined: 19/05/2015 Posts: 1,419 Points: 4,272 Location: Darmstadt, Germany
Sweet, another tiger. Gonna be looking forward to this one.
Quick question whats the best way to paint the tracks links conect all together or one at a time building the spitfire,RMS Titanic hachette and now starting the u-96 submarine
Personally I would paint them once assembledas the easier method. You could paint prior to assembly but you would more than likely need to apply some touch up once assembled.
Yeah that what i was thinking whats the best way to remove that silver paint on it would rubing alchol work building the spitfire,RMS Titanic hachette and now starting the u-96 submarine
 I always assemble my Friul tracks then paint with Tamiya metalic grey XF-56 and would reccomend this way to anyone Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
I was looking for red oxide spray as i dont have a air brush and i cant find any what would i be looking for thanks building the spitfire,RMS Titanic hachette and now starting the u-96 submarine
 Here you go, http://www.wickes.co.uk/...ay-Paint-400ml/p/194167
Not cheap but should cover a fair amount of metal, its also not acrylic based so ventilation may be in order. Or you could use Tamiya's flat red brown TS-1, https://www.wonderlandmo.../tamiya-ts-1-red-brown/
Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
I use Simoniz Red Oxide, works well.
 Been dry fitting the hull and have found a problem with the rear wall anyone had this building the spitfire,RMS Titanic hachette and now starting the u-96 submarine
Didnt have a problem with mine.
Haven't tried mine yet but looks like some filler would.sort that nicely
Seems that the bottom is longer than what it is ment to be but it might just be me. I thought that it should off been flush as it has been angled and the wall has been angled for it to fit flush.might be a case of sanding it fown abit building the spitfire,RMS Titanic hachette and now starting the u-96 submarine
 . This is a better photo building the spitfire,RMS Titanic hachette and now starting the u-96 submarine
After dry fiting the turret walls to the turret ring everything is not lining up have to say the turret desighn is not the best desighn ever. After filing and cutting away at the ring still not a great fit another issue of the turret ring on the way hope i have better luck with this one building the spitfire,RMS Titanic hachette and now starting the u-96 submarine
