32 Pages «<2425262728>»
michael.rolph
#501 Posted : 21 October 2015 13:47:57
You could also only part plank the Perspex deck so you could see through the deck into the hanger.
#502 Posted : 21 October 2015 21:24:00
BigGrin Hi Nem and Micheal
Thanks both of you for looking in and your comments, Micheal the perspex is a black colour so not see through but its a good idea.
#503 Posted : 25 October 2015 20:25:42
More progress the hull, all ladders have now been fitted along with the odd piece of furniture then all the railings were fitted. The main flight deck has been glued in place at the bow and the perspex deck has been cut out with my lecky fretsaw. In the pics the cut out deck has not been glued as yet along with the stern deck as some adjustments will be needed here and also some boats and furniture needs to be added here. More soon.
#504 Posted : 26 October 2015 12:13:38
wow look`s mint BigGrin i think i might go down the perspex route andy.
#505 Posted : 26 October 2015 20:02:03
BigGrin Hi tigerace
Thanks for looking in and your comments, Just having the flat top on makes all the difference I think.
#506 Posted : 27 October 2015 00:21:53
She's some size of a build... looks fab Andy.... Cool Cool
#507 Posted : 27 October 2015 02:00:40
She's an amazing looking carrier and looks like you've done a pretty amazing job on her too ThumpUp
#508 Posted : 01 November 2015 19:24:40
BigGrin Thanks for looking in both of you and your commentsCool
#509 Posted : 01 November 2015 19:35:40
A little more done the central deck has had the underneath roughed up, primed and painted underneath and along the edges where it will be visible. I have left the upper protective cover in place as its a guide to replace the various refuges and girder work removed from the four original deck pieces. Next job is to replace these pieces and then the final fitting of the stern deck so the planking can go on. More soon.
#510 Posted : 01 November 2015 21:10:43
Loving your build Andy, definitely one to live up to.
#511 Posted : 01 November 2015 21:45:47
Nice progress andy. Loving this build.
Chris
#512 Posted : 02 November 2015 01:08:18
Another great update Andy, usual top notch work I see.....Cool Cool
#513 Posted : 02 November 2015 09:38:19
BigGrin Stunning work as always Andy Cool
Reg Martyn
jural
#514 Posted : 02 November 2015 16:50:11
Looking good.
I'm taking notes as I made a start on my Akagi but found to have a few bits missing, waiting on admin to replace them
#515 Posted : 02 November 2015 23:51:07
BigGrin Thanks for looking in and your comments everyone, there all very much appreciatedCool
#516 Posted : 04 November 2015 20:11:40
Just a quick update, the four prop shafts have now been added to the hull.
More soon
#517 Posted : 05 November 2015 12:30:49
nice work andy BigGrin the plastic card round the propshaft ends are your enhancement ? cheer`s phil
#518 Posted : 05 November 2015 14:41:41
Sterling work there Andy. beautiful work
#519 Posted : 05 November 2015 19:08:40
BigGrin Hi Tigerace
Yes the plasticard inserts are enhancements that represent the rivet flanges that surround these parts on real ships, I have also some faired brass section that was used on the Yamato build but it just a little too big for this build so stuck with the supplied ali bar. Thanks for looking in and your comments.
#520 Posted : 05 November 2015 19:09:51
BigGrin Hi Hans
Guest (6)
This page was generated in 0.260 seconds.
