Cut one engine cover label B (numbered 23) from the sheet. Peel away the backing paper from the curved end, and apply the label to the left side of the cover, starting at the back. Work along the bottom edge to the end, then trim off any excess. In the same way, apply an engine cover label B (number 24), to the right side of the engine cover. When you are finished, pierce through the six mounting holes that the labels are covering.
Does anybody know what part of the engine cover this refers to as I cannot see the photo on the official build.
 Hi JD The Decal you are refering to is the one that runs along the bottom edge of the body work engine cover. I have included a pic to help you out. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,495 Points: 4,397 Location: Essex
These are the long thin black decals supplied in stage 67 which go along the Base of the engine cover. These decals cover the 3 engine cover mounting holes on each side so they will need to be pierced through for the screws. I assume! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
There you go, beaten to it Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Thanks for the information. Andy could you post your photo again as it won't open for me.
Photo showing now...many thanks
The instructions of Pack 20 clearly show the decal placement, which when Warthog can acces the forum he'll update his build images to show it, but for now here are the images from the instructions..Tomick attached the following image(s):
