5 Pages 123>»
Graeme's HMS Hood build Options
#1 Posted : 08 November 2015 15:09:12
I have been planning, researching and collecting materials for this build for the last 18 months.
The build will be a static display model of HMS Hood as she was in her final configuration. The build will be a long slow process and will be carried out along side my U96, Akagi and Victory builds.
The build is based on the 1/128 GRP hull produced by Fleetscale and resin primary and secondary armament and ships boats have been purchased although these will be modified as the build progresses. Photoetch rail stantions and companionways have also been purchased although I am going to attempt making my own photoetch frets for the UP launchers. Almost everything else will be scratch built.
The hull is approx 2040mm long and 220mm beam and has all the plating detail moulded into it, pics 1,2 & 3. Some of the surface detail, such as portholes, will be removed and replaced.
I have marked and drilled 4 4mm holes in the base of the hull and glued steel plates (which have drilled and tapped to to take M4 screws) to the inside to which brass pedestals will be attached for display purposes, pic 4.
The next job will be to mark and drill the holes for the prop shafts and to make and attach the bilge keels. I also have to finish machining the prop shafts and 'A' frame bearings.
Well that's it for now
pemberg attached the following image(s):
#2 Posted : 08 November 2015 15:43:00
wow looking forward to following this build along with your other`s Graeme BigGrin phil
daffy09
#3 Posted : 08 November 2015 16:55:22
Nice one Graeme, I'm looking forward to following her taking shape.
Happy building
David
#4 Posted : 08 November 2015 17:02:57
WOW Blink that is a beast. Grabbing my pop corn and settling in for the long haul Drool Drool Cool
#5 Posted : 08 November 2015 18:48:28
BigGrin Wow that is one Big ship looking forward to seeing this build Cool
Reg Martyn
#6 Posted : 08 November 2015 18:54:53
This is a build I will relish following, she's going to be a very impressive beast when done..... Good luck with the build and can't wait for your next update.....Drool Drool
#7 Posted : 08 November 2015 18:59:10
Hi looks a great hull you have there an will be a great diary to follow.await with interest. Cheers mick.Drool
#8 Posted : 08 November 2015 19:00:10
#9 Posted : 08 November 2015 20:22:11
BigGrin Looks like a long term project there and what a nicely moulded hull will be following with interestCool
#10 Posted : 09 November 2015 11:45:14
Fleetscale are leaders in large scale RC ship kits and the Hood being one of the most popular.
A great start and look forward to seeing how you get on, at least you don't have hours of seemingly endless hull planking to complete Cool
#11 Posted : 09 November 2015 12:01:59
Thats one awesome Hull. Look forward to seeing her progress. She wll be a beauty.
Chris
#12 Posted : 27 November 2015 13:11:45
Hi, Ihave been doing a few bits on the build.
I have started to make the rudder. I first cut 2 pieces of 1mm thick plastic sheet to the correct shape and glued them together, pic 1. I then glued on a piece of 4.8mm plastic tube to act as the rudder post and then glued a piece of 0.25mm plastic sheet to each side of the rudder to bring it to the correct thickness and overlapping the rudder post to reinforce it, pic 2. The rudder will be sanded to shape once fully dry. I will fix it to the hull by drilling a hole through the hull and lower fixing point and then passing a plastic rod through the hull and rudder.
I have also started cutting the ahull access for the prop shafts, pic 3. It looks a bit messy at the moment but once the bulges around the hull entry bearings are made and fitted it will be fine.
I did make the the prop shafts a while ago from 5mm stainless steel rod but i have since found that 2 of these are too short so will have to redo them but I can use the other 2 to position and make the 'A' frame support bearings.
Getting away from the hull I have also started to make the 4" gun ready lockers, of which there are many. I made 2 lockers from plastic sheet, strip and brass wire (each having about 30 component parts)Pic 4.
I then made a silicone mould of these (my first attempt at this) and then cast more lockers in resin. Pic 5 shows one of the first lockers cast, not too bad for a first attempt, only a few small pinholes. The resin I was using only had a 90 second pot life so it didn't allow much time to get into all the fine detail. I have since ordered different resin with a 3 minute pot life which should make life easier.
I have started to work on the bilge keels but have no photos of them yet.
#13 Posted : 28 November 2015 00:17:29
Very nice Graeme, love it already.....Drool Drool
#14 Posted : 28 November 2015 00:40:02
BigGrin Nice work Graeme, casting the lockers is the way to go there are loads of them as for pin holes Mr hobbys Dissolved putty is great for filling them.
http://www.ebay.co.uk/it...5615:g:FsIAAOxyVaBS2qss
I too found the resin kit I got would go off too fast and went for a slower set like yourself although I also found that it runs out fast when you start castingCool
#15 Posted : 28 November 2015 13:29:17
Thanks for the comments. I have used the dissolved putty on my U 96 build, in fact I think it was yourself that recommended it then.
#16 Posted : 28 November 2015 13:34:46
Fabulous work Graeme and those locker doors are superb for a first attempt at casting them yourself? Well done that man, a very praiseworthy effort indeed! Cool Cool ThumpUp
#17 Posted : 10 February 2016 12:52:06
Hi Greame.
Looking forward to seeing this monster coming together. IanCool BigGrin
#18 Posted : 03 March 2016 14:47:07
I have done a little more on the build though it's always easy to find space to work on a hull this size.
I have started on the inboard prop shaft 'A' frames. Pic 1 shows the the lower support cut from brass sheet with 2 locating pins soldered into it. Pic 2 shows the prop shafts temporarily in place with a plywood former to hold them in the correct position and pic 3 shows the lower support in place ready to be soldered.
Pic 4 shows the lower support soldered and the rudder sat in place to check positioning. The rudder still needs to be sanded to its final shape.
Pic 5 shows the other half of the 'A' frame soldered in situe with a piece of heat resistant tile behind it so as not to affect the hull. A small butane gas torch was used to do the soldering. The parts still need to be cleaned up.
Pic 6 shows the inner 'A' frame sat in place with the outer prop shafts held in place with plywood ready to start fitting the outboard 'A' frames.
I have also had a go at making my own photoetch parts for the UP launchers framework, the barrels will be brass tube from Albion alloys and the mounts will be made from sheet plastic. I did the artwork for the fret on Google sketchup and followed instructions found on the internet for producing the etch brass. It took a couple of attempts to get the UV resist to sit on the brass with no air bubbles between the brass and resist and Pic 7 & 8 show the result of my first go at etching.
That's it for now
#19 Posted : 03 March 2016 19:45:21
Looking great Graeme and I can quite imagine you'll run into one or two problems dealing with a build of that size but am sure you'll master it.....Cool Cool .. Keep the pics coming....
kpnuts
#20 Posted : 03 March 2016 19:59:07
Now, that, is, big looking forward to this.
5 Pages 123>»
This page was generated in 0.291 seconds.
