 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,510 Points: 4,442 Location: Essex
When gluing the nose mounting plate to the front of the monocoque it says that you should put glue only on the top of the monocoque and not all the way round the sides. Why is this? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
Hi Steve I'm guessing so that it limits any glue possibly oozing out to the edges and on to the paint work plus the lower body panel will hold it in to place as you can see by the 2 recesses on the end plate. Regards Spencer
ok, cheers Spencer Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
