Not a build diary as such but just a quick photo of my progress to date. just got the decals to add when I get time.
 Looks great and well done, will you be roughing up the tyres also Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Not made up my mind about the tyres yet,they do look a bit too bright really but I am wary of spoiling them if I attempt it. Shame they did not supply them with a duller finish.
another build photo
 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,510 Points: 4,442 Location: Essex
Looking good. Well done on your build. The tyres are not hard to do, it's just a bit time consuming. I used 1500 grit paper and this is how they came out.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
They look great,how did you get the nice sharp edge on the side of the tyre?
It's just the natural edge. As Long as you sand them horizontally then this edge will be there naturally. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
I will give it a go as I have a couple of spare tyres. Thanks for the advice.
Something to be proud of Tony. Very nice job you have done there. Spencer
Joined: 01/12/2014 Posts: 102 Points: 312 Location: Chicago, IL
Don't be scared about sanding the tires. I actually used a 800 grit I think -- but if you are hesitant, you can start off with a higher grit as to be not as aggressive and work your way down if you feel it not intensive (both physical and time wise!).
Joined: 08/11/2012 Posts: 195 Points: 600 Location: Melbourne
Looks great :-)
Can't wait for mine to arrive from the UK so I can carry on with it!
Dave
 Finally completed the model. Waiting for a display case to come and then will have the problem of finding somewhere to put it!!
Very nice, just got them tyres to do now Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Not going to do the tyres!
In its display case
