 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,510 Points: 4,442 Location: Essex
I see you have a bit of a gap between the plenum and the intercooler pipes like I have. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
 Looking sweet just got my pack 19 so will be posting soon Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
RM1 wrote:Looking good. The extra details are excellent. May I ask what paints you used on the exhaust pipe? Malc. Hi Malc thanks for looking in and your kind comments.i used Alclad paints, so started with the gloss black base, then used ALC-115 Stainless steel, i then shot a very faint layer (in certain places) of ALC-104 Pale burnt metal and the same with ALC-416 Hotmetal serpia. once all dry a layer of ALC 600 Aqua gloss was applied and again once that was fully dry i used the tamiya weathering master kit "burnt Blue" for the final touch. regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Steve279021 wrote:I see you have a bit of a gap between the plenum and the intercooler pipes like I have. hi Steve, yes a little gap is visible, however i have not got round to adding a clamp of some sort similar the the lower clamps, im still playing around with the color so the lower ones may change soon. dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
arpurchase wrote: Looking sweet just got my pack 19 so will be posting soon i dribbled a little when i got my pack 19 just looks fantastic with that body regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Joined: 11/12/2015 Posts: 1 Points: 3 Location: Brazil
dandare wrote:ive added the carbon decal to the nose box, with a little smoke to tone it down a bit, also cut off the plastic fixing brackets and made some out of aluminium. i went for a matt finish then rubbed it over with 400 paper to get a few scratches & a rough look to it. decals fitted to the rear wing.
regards Dan Hello Dandare, nice Work. I am from Brazil and I am new on ModelSpace. Actually this is my first question in the forum. Before added the carbon decal to the nose box, did you apply any Primer ? The smoke was before or after add the decal ? Thank you very much, sorry about my English, Marcello.
MarcelloF wrote:dandare wrote:ive added the carbon decal to the nose box, with a little smoke to tone it down a bit, also cut off the plastic fixing brackets and made some out of aluminium. i went for a matt finish then rubbed it over with 400 paper to get a few scratches & a rough look to it. decals fitted to the rear wing.
regards Dan Hello Dandare, nice Work. I am from Brazil and I am new on ModelSpace. Actually this is my first question in the forum. Before added the carbon decal to the nose box, did you apply any Primer ? The smoke was before or after add the decal ? Thank you very much, sorry about my English, Marcello. Hi Marcello welcome to the forum sorry for not responding sooner, ive been very busy lately and been unable to do much if any modeling. i primed and painted the nose prior to applying the decal, as the decal itself is transparent and needs a base color. once this was done i applied the decal and then added a light smoke topcoat to dull down the brightness of the base color, which i think i used a mix of aluminium & gunmetal many regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Very nice work Dan, you should be proud of what you've done so far, she's looking great and one of the better MP4/4 builds on the forum in my opinion!
Well done!!
Kev
ModelMania wrote:Very nice work Dan, you should be proud of what you've done so far, she's looking great and one of the better MP4/4 builds on the forum in my opinion!
Well done!!
Kev  Thank You Kev extremely appreciated comment coming from such a fine builder as yourself i would love to have more done at this stage but ive been way to busy. i have managed to prime the main body ready for paint and will post some piccys up soon regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Beautiful work Dan and agree with Kev, some lovely details you've added to make this one different and stand out from the crowd Spence
 Looks great Dan Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
dandare wrote:ModelMania wrote:Very nice work Dan, you should be proud of what you've done so far, she's looking great and one of the better MP4/4 builds on the forum in my opinion!
Well done!!
Kev  Thank You Kev extremely appreciated comment coming from such a fine builder as yourself i would love to have more done at this stage but ive been way to busy. i have managed to prime the main body ready for paint and will post some piccys up soon regards Dan No worries Dan, I always give credit where it's due and thank you very much for the compliment, very kind of you and equally appreciated!
Kev
Thank you for the kind comments guys, very much appreciated from 3 great modelers  . well im still busy as a bee, but managed to find some time for the bodywork, some filler, primer, more filler, more primer you know how it goes. well got the body to a point that it was ready for the base coat! and also managed its first tack coat of lacquer. hopefully over the next few days i can get the decals on and another tack coat of lacquer before applying the first wet coat. dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
 Looking good D  an Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Wow, you're a brave man! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Very nice indeed, am tempted to do this with mine.
Very nice work with the respray Dan and I think for those that have the skills to take that modification on, it will pay great dividends in the look of the car at the end!!
Well done - I'm impressed with what you are doing to your build. One to watch!!
Kev
arpurchase wrote: Looking good D  an Thank you Andy, much appreciated Regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Steve279021 wrote:Wow, you're a brave man! Thanks for looking in steve i wouldn't say brave, might be stupid if i get it all wrong regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Nemesis wrote:Very nice indeed, am tempted to do this with mine. Hi Nem thanks for looking the kit is great as is and does not need anything doing to it for it to stand out, but having got back into modeling i just thought i could add that little bit extra Regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
